What is permanent magnet B field equation?
The discussion focuses on calculating the magnetic field (B) between two permanent magnets positioned 10mm apart, each with a core intensity of 1.3T and a surface intensity of 0.6T. The B field at a distance of 5mm from each magnet can be approximated using the formula for the electric field (E) of a uniformly charged disk, with the charge density set to 13,000 gauss. The calculation involves doubling the result for two magnets. A specific formula for calculating Tesla (B) in this context is sought for practical applications.
  • Understanding of magnetic field concepts, specifically permanent magnets.
  • Familiarity with Gaussian units and their application in magnetic field calculations.
  • Knowledge of electric fields generated by uniformly charged disks.
  • Basic algebra for manipulating equations related to magnetic fields.
  • Research the formula for the electric field of a uniformly charged disk in textbooks.
  • Explore the relationship between magnetic field intensity and distance for permanent magnets.
  • Investigate the effects of magnet dimensions on magnetic field calculations.
  • Learn about the application of Gaussian units in electromagnetic theory.
Engineers, physicists, and hobbyists working with magnetic systems, particularly those involved in designing or analyzing the interactions between permanent magnets.
ShahinPhD
I'm looking for an equation to calculate Tesla (B) between two permanent magnets with distance of 10mm.
Magnets are located in front of each other; disk shape and intensity of each is 1.3T in its core, and 0.6T on surface, so I'm interested how to calculate the B between them in distance of 5mm from each one (10mm between 2 magnets).
Please help me to find proper calculation.
Thanks in advanced.
If the magnets are much longer than 5mm, the B field 5mm from the face of one magnet is the same as the E field 5mm from a uniformly charged disk with charge density
\sigma=M where M=13,000 gauss (all in Gaussianl units). Just double it for two magnets.
Thanks for your fast response.
It seems OK, but in a short form I'm looking for a formula to calculate the Tesla in distance between two magnets.
Suppose we have some parameters: dimensions of magnets, power of magnets in core and surface, distance between them; so how can we use a formula to calculate intensity between magnets in some distance?
(Frankly I'm looking for a formula to use for my calculations)
The on axis formula for E due to a uniformly charged disk is in most (even elementary) textbooks.
  • · Replies 31 ·
