What is Spanning and its Relation to Dimensionality?
  • Context: Undergrad
  • Thread starter Thread starter Saggittarius
9 replies · 3K views
Saggittarius
I'm a little confused on exactly what spanning is. For example, It's not possible for a set of five vectors to span M(2, 3), but it is possible for a set of six vectors or seven vectors. Why is this? I understand the dimension of M(2,3)=6. I just need a little bit more information on what spanning is.
The span of a set of vectors is the vector space of minimal dimension that contains those vectors.
As you say you understand what dimension is - the size of a minimal spanning set - then it should now seem tautologous to say that a 6 dimension space cannot be spanned by 5 vectors: a set of 5 vectors can span a vector space of dimension *at most* 5.
o ok.. thanks so much!
Span
I have a problem. How do I prove that span{u,v} = span{u,v,w} if w is an element of the span{u,v), in R^n.
I don't know how to do this.
Any ideas anyone.
You use the definitions:
(a,b,c,d,e,f,g represent elements of the base field)
span(u,v) is the set of things of the form au+bv
span(u,v,w) is the set of things of the form cu+dv+ew
w is in span(u,v) means w=...?
Thanks for that.
I'm just having trouble getting started
I can't seem to do it.
Damn it's quite hard.
Any help would be greatly appreciated.
Yes I have done that.
