Synodic Period: Definition & Equation
  • Thread starter Thread starter Greg Bernhardt
The synodic period refers to the apparent rotational or orbital period of one astronomical body relative to another, specifically the time between successive oppositions or conjunctions. An example is the synodic month, which is the duration from one full moon to the next, taking about 29.53 days, longer than the sidereal month due to Earth's movement in its orbit. The synodic period can be calculated using the equation 1/T_syn = 1/T_1 - 1/T_2, where T_1 and T_2 are the sidereal periods of the two bodies. For instance, the synodic period of Mars as observed from Earth is approximately 779.95 days, derived from their respective sidereal periods. Understanding synodic periods is essential for comprehending the timing of celestial events.
Definition/Summary
Dealing with the apparent rotational or orbital period of an astronomical body with respect to another body or the period between successive oppositions or conjunctions.
Equations
\frac{1}{T_{syn}}= \frac{1}{T_1}-\frac{1}{T_2}
Extended explanation
An example of a synodic period is the synodic month, or the time it takes the Moon to go from full moon to full moon. When you start at one full moon, the Earth, Moon and Sun are in a straight line, with the Moon directly opposite the Sun. The next full moon will occur when the Moon is again opposite the Sun. In the time it takes the Moon 360° around the Earth once, the Earth itself has moved a few degrees in its orbit, making the Moon have to travel a few degree past 360° to realign with the Sun to produce the next full moon. This is why the synodic month is about 2 days longer than the sidereal month.
Conjunctions occur when two planets line up with the Sun on the same side of the Sun(or two moons line with their planet). The synodic period is the time between successive conjunctions. Again, since the outer planet will have traveled in its own orbit while the inner planet completes one orbit, the inner planet will have more than 1 complete orbit in order to catch up to the outer planet.
The synodic period is found by taking the reciprocal of the difference of the reciprocals of the sidereal periods of the bodies involved.
For example: Earth's sidereal period is 365.26 days and Mars' sidereal period is 686.98 days.
Thus the synodic period of Mars as seen from Earth is
\frac{1}{T_{syn}} = \frac{1}{365.26}-\frac{1}{686.98}
or 779.95 days.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Astronomy news on Phys.org
Thanks for the explanation! This is really helpful in understanding synodic periods and equations.
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
12K
