What is the acceleration of the car?
  • Thread starter Thread starter tica86
    Acceleration Car
The acceleration of a car sliding down a 10-degree icy driveway is calculated to be 1.7 m/s², derived from the equation a = g sin(10°). The forces acting on the car include its weight, normal force, and the horizontal component of gravitational force. A follow-up question addresses finding the net force needed to accelerate a 110 kg bike and rider from rest to 22.7 m/s in 10 seconds. The correct approach involves first calculating the average acceleration and then applying the formula F = m*a to determine the net force. Overall, the discussion emphasizes the application of basic physics principles to solve motion-related problems.
tica86
A car is slides down an icy driveway that slopes at an angle of 10 degrees. What is the acceleration of the car?
Is the correct answer a=1.70m/s^2?
If it is can someone explain how they figure it out, thanks!
Forces acting on the car:
Weight = mg
Normal = mg cos 10 (deg)
Horizontal = mg sin 10
macar = mg sin 10
cancel out m,
acar = g sin 10 = 1.7 m s-2
So yes, 1.7.
Weight = mg
macar = mg sin 10
cancel out m,
So yes, 1.7.
Ok, thanks. I have another question:
Find the net force (in Newtons) required to accelerate a 110 kg bike and rider from rest to a final velocity of 22.7 m/s in 10 seconds?
since f=ma 110(22.7)=2497 do I divide that by 10 seconds??
not exactly...
first solve for average acceleration using equations of motion...
then use the F=m*a and get your answer! :smile:
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 48 ·
9K
  • · Replies 17 ·
