What is the algebraic function for solving polynomial equations?
  • Thread starter Karol
    Function
9 replies · 2K views · last reply
Karol
Printed problem 7 text: Show that the function f defined by f(x) = x^(2/3) is an algebraic function by finding an appropriate equation of the type (α) in the definition in Problem 6 above.
Algebraic Fuction:
$$P_0(x)y^n+P_1(X)y^{n-1}+...+P_{n-1}(x)y+P_n(x)=0$$
##P_i(x)~## are polinomials, ##~P_0(x)\neq 0##
$$\left( x^{2/3} \right)^3 (1-x)+\left( x^{2/3} \right)^2(x)=x^2-x^3+x^{5/3}$$
Any integer exponent can't cancel the ##~x^{5/3}##
$$y=x^{2/3} \rightarrow~y^3=\left( x^{2/3} \right)^3=x^2$$
Yes, and now you need to write it ##...=0## to see what ##P_0(x)## and ##P_3(x)## are.
$$P_0(x)x^2+x^{\frac{5}{3}}+P_3(x)=0$$
P0 and P3 are dependent on each other, i have to choose one:
$$\Rightarrow~P_0(x)=-\frac{-P_3(x)-x^{5/3}}{x^2}-x^{-\frac{1}{3}}$$
No polinomial will result
Why so complicated? It is far, far easier than this. You already have ##y^3-x^2= 0##. All you have to do is to write down the coefficients of ##y^3,y^2,y^1,y^0##.
I don't have ##~y^3-x^2= 0##. I assume you use only: ##~\left( x^{2/3} \right)^3 (1-x)=x^2-x^3##, or, maybe you have made a mistake, it's: ##~\left( x^{2/3} \right)^3 (1-x)=y^3-x^3##
The coefficient of y3 is, as i chose: ##~(1-x)##
$$(1-x)y^3+P_1(x)y^2+P_2(x)y-x^3=0$$
Is it the equation? i arbitrarily chose 3d degree and the coefficient P0=1-x
Why did you choose ##1-x##? Why not just ##1##?
Karol said:
I don't have ##y^3-x^2= 0##.
What about:
Karol said:
##y^3=(x^{2/3})^3=x^2##
You only have to compare ##y^3-x^2= 0## with ##P_0(x)y^3+P_1(x)y^2+P_2(x)y+P_3(x)=0##.
Now what are the choices for the ##P_i##?
$$1\cdot y^3+0\cdot y^2+0\cdot y-x^2=0$$
