What is the angle between a rolling ball and the surface it leaves?
  • Thread starter Thread starter Ihatemiu
    Rolling
The discussion revolves around a physics problem involving a small ball rolling down the surface of a larger stationary ball. Participants are exploring the angle at which the small ball leaves the surface of the larger ball, considering factors such as rolling without slipping and the implications of circular motion.
  • Participants question the conditions under which the small ball rolls versus slips, and whether additional information is needed to solve the problem. There are discussions about the role of friction and the moment of inertia in the context of rolling motion.
The conversation is ongoing, with participants offering insights into the complexities of the problem. Some suggest starting with a simpler point mass scenario before tackling the rolling case, while others highlight the importance of understanding the conditions for slipping and rolling contact.
There are references to previous discussions on similar problems, indicating that the relationship between slipping and rolling is a significant aspect of the current problem. The need for specific parameters, such as the coefficient of friction and the moment of inertia, is also noted.
Ihatemiu
Situation: There is a big ball that never moves, and a small ball on it.
If we let the small ball roll down from the big ball, what is the angle that between the top of the big ball and the place that the small ball leaves the surface of the big ball?
Or do we need more information about situation?
Maybe equation about circular motion?
I tried to let R=0 to my calculations but I found out that the angle=0
Did you make this question up yourself? Are you sure the small ball rolls and isn't slipping?
My teacher asked me today. What about the ball roll down without slipping?
That's a harder problem. What are your thoughts about what's happening and why the small ball eventually leaves the surface? Hint: circular motion is important here.
PS There was a problem on here not that long ago to prove that the small ball must slip before leaving the surface.
The simpler and solvable problem is to consider the small ball as a point sliding down the large ball.
Yes, for any given coefficient of friction, sliding must occur before losing contact completely. On the other hand, the difference between those two angles can be made as small as you like by making the coefficient large enough. So by allowing an arbitrarily large coefficient, it is reasonable to treat it as though rolling contact is maintained.
With that simplification, is it much harder than the sliding point mass case?
I suppose in the rolling case one needs to know the ratio of moment of inertia to mass for the small ball, in order to take proper account of its rotational energy, and that would depend on whether it was solid or hollow. Whereas in the non-rolling case one can reasonably take the small ball as a point mass, provided it's small enough.
True, but one could start with an arbitrary radius of inertia, k, and obtain a general solution.
It's a good point. If we simply assume that the ball keeps rolling until it loses contact, then it's a nice problem. It's a little bit harder than the point mass problem. And, it's simpler to assume that the small ball has a much smaller radius than the large ball.
My advice to the OP would be to do the point mass problem first, then consider a small rolling ball (and assume it doesn't slip).
  • · Replies 28 ·
  • · Replies 60 ·
