What is the angle between vector a and b if a=-4i-2j and b=i-7j?
  • Context: MHB
  • Thread starter Thread starter karush
    Angle Vector
The discussion revolves around finding the angle between two vectors, \( a = -4i - 2j \) and \( b = i - 7j \), using the dot product method. Participants explore the calculations involved and address some confusion regarding the notation used in the problem.
  • One participant calculates the dot product of vectors \( a \) and \( b \) and derives the angle \( \theta \) to be approximately \( 72^\circ \).
  • Another participant expresses agreement with the calculation presented.
  • Some participants question the use of different variable names \( u \) and \( d \) instead of \( a \) and \( b \), suggesting it creates confusion.
  • There is a suggestion that the change in variable names is likely a typo.
  • One participant expresses concern about the editing of posts, feeling it undermines their contribution.
While there is some agreement on the calculations, there is disagreement regarding the notation and clarity of the problem, with multiple participants expressing confusion about the variable names used.
The discussion highlights potential issues with notation and clarity in the problem statement, which may affect understanding. There is no resolution on the appropriateness of the variable names used.
karush
MHB
$$a=-4i-2j$$ and $$b=i-7j$$
$$a\cdot b=(-4)(1)+(-2)(-7)=10$$
$$||a||=\sqrt{(-4)^2+(-2)^2}=2\sqrt{5}$$
$$||b||=\sqrt{1^2+(-7)^2}=5\sqrt{2} $$
$$\cos\theta = \frac{10}{10\sqrt{10}}$$ so $$\theta\approx72^o$$
Re: angle between vector a and b give answer to nearest degree.
Looks good to me! (Sun)
Thnx to MHB I make some progress...
Frankly, it doesn't make much sense to me. You give two complex numbers, a and b, and then immediately take the dot product of two vectors, u and d. Where are u and d defined?
I presume that you are taking u= a and v= b but I don't see why you changed their names.
You're correct, the original problem just uses $a$ and $b$; $u$ and $d$ should not be used.
I expect it's just a typo, and u is supposed to be a and d is supposed to be b.
Hey, no fair editing after my post- that makes me look like a fool! (And I was hoping I could keep that quiet.)
