What is the Angular Speed of a Reel Connected to a Spring and Cord System?
The discussion focuses on calculating the angular speed of a reel connected to a spring and cord system. The problem involves a reel with a moment of inertia (I) and radius (R), where a block of mass (m) is attached to a spring with force constant (k). The solution requires applying conservation of mechanical energy to relate the rotational kinetic energy of the reel and the linear kinetic energy of the block to the potential energy stored in the spring and the gravitational potential energy. Numerical evaluation is provided for specific values: I = 0.50 kg·m², R = 0.300 m, k = 50.0 N/m, m = 0.550 kg, d = 0.200 m, and θ = 37.0°.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with conservation of mechanical energy principles
  • Knowledge of linear and rotational kinetic energy equations
  • Basic trigonometry for resolving components of forces and distances
  • Study the principles of conservation of energy in mechanical systems
  • Learn about the relationship between linear and angular velocity
  • Explore the equations for rotational kinetic energy and moment of inertia
  • Investigate the effects of spring constants on oscillatory motion
Students in physics or engineering courses, particularly those studying dynamics, mechanics, or systems involving rotational motion and energy conservation.
yb1013
The reel shown below has radius R and moment of inertia I. One end of the block of mass m is connected to a spring of force constant k, and the other end is fastened to a cord wrapped around the reel. The reel axle and the incline are frictionless. The reel is wound counterclockwise so that the spring stretches a distance d from its unstretched position and is then released from rest.
http://s721.photobucket.com/albums/ww212/yb1013/?action=view&current=k.gif&newest=1
(a) Find the angular speed of the reel when the spring is again unstretched. (Answer using theta for θ, g for the acceleration due to gravity, and R, I, m, k, and d, as necessary.)
(b) Evaluate the angular speed numerically at this point if I = 0.50 kg·m2, R = 0.300 m, k = 50.0 N/m, m = 0.550 kg, d = 0.200 m, and θ = 37.0°.
ω = ________ rad/s
F = ma
t = Ia
I got through all the other questions on my homework but this one is just giving me a rough time. I really don't know where to start on this question, could somebody please help?
The angular speed of the reel is related to the linear speed of the block. Conservation of mechanical energy might tell you the total kinetic energy of the system, from which you can get the speeds.
yeaa, I kind of understand how the system works and what you need for the angular speed, but my real problem comes about on part a. I have no idea how to state it using all those variables..
Well, I would start by solving for the linear velocity of the block in terms of omega and the vertical distance the block moves in terms of d and theta.
Then I'd set up a conservation of energy equation: (rotational kinetic energy of reel in terms of I and omega) + (linear kinetic energy of block in terms of m, R and omega) = (change in spring potential energy from spring contraction in terms of k and d) + (change in gravitational potential energy from loss of height in terms of m, d and theta).
The above equation should have all the right variables in it; all that should be left for you to do is some algebraic manipulation (I believe you'll be able to factor out an omega^2 from the left side, and from there it should be easy).
this is very frustrating... lol
when you explain it, the problem sounds so simple, but when I actually try to put it together, I keep getting the wrong answer and I know I am just doing something wrong..
when your supposed to put equations together while only using the variables, I always get extremely confused... I get the first KEr, but then i don't get how to put KEl in terms of m, R, omega and so on.. I think i might be helpless on this problem..
I'm sure you can get it. Have you figured out v in terms of r and omega? Think about it: the block is moving at the same speed as the string holding it, which is moving at the same speed as the outer edge of the reel. The reel is spinning at omega radians per second, and the outer edge is moving a linear distance of r meters per radian - some dimensional analysis gives you v = r*omega meters per second.
So you plug that formula for v into the equation for linear KE: KEl=1/2 m*v^2 = 1/2 m*(r*omega)^2 = 1/2 m*r^2*omega^2.
You should already have KEr=1/2 I*omega^2. So, factoring out an omega^2, the left side of the equation should look like:
omega^2 (1/2 I + 1/2 m*r^2)
Any progress on the right side (the potential energies)?
ooo ok, i think I've figured it out, that definitely cleared it up a lot more.
thanks a lot man!
