How Does Angular Acceleration Affect Angular Velocity?
The discussion focuses on calculating the angular velocity of a grinding wheel after a constant tangential force is applied. Given the wheel's radius of 0.330 m, a force of 270 N results in an angular acceleration of 0.984 rad/s². Starting from rest, the angular velocity can be determined using the formula ω = αt, where α is angular acceleration and t is time. After 4.30 seconds, the angular velocity can be calculated, but the user is uncertain about the correct equation to use. The conversation emphasizes understanding the relationship between angular acceleration and angular velocity in rotational motion.
ymehuuh
A large grinding wheel in the shape of a solid cylinder of radius 0.330 m is free to rotate on a frictionless, vertical axle. A constant tangential force of 270 N applied to its edge causes the wheel to have an angular acceleration of 0.984 rad/s2.
If the wheel starts from rest, what is its angular velocity after 4.30 s have elapsed, assuming the force is acting during that time?
Moment of intertia is 90.457kg/m2
mass of wheel is 1661.29kg
I was able to find moment of inertia and mass of wheel above...not sure about angular velocity. I can't find the right equation what uses I.
nm...it was just w=at
  • · Replies 19 ·
16K
