The above is a drawing. It is not an accurate representation, as it exaggerates the scales for illustrative purposes. On a to-scale picture one wouldn't see anything - no asteroids, no planets - just black space with a bright dot in the middle.
Here's how the densities of the two belts can be roughly compared, using commonly accessible data:
Let's assume the distribution to be doughnut-shaped, which it roughly is. Most asteroids lie between 2 and 3 AU, at inclinations lower than 15 degrees. We can approximate it as a torus at the distance of 2.5 AU, with 0.5 AU thickness (I.e. R and r, respectively).
The mass in the KB is mostly concentrated between 30 and 50 AU, at inclinations of less than 10 degrees. Let's assume a torus at R=40 AU with r=10 AU thickness.
Comparing the two volumes, we find out that the KB occupies roughly 6.7 thousand times more space than the AB.
At the same time, the mass contained within the AB is roughly 4% of the mass of the Moon, which is about 5 thousandth of the mass of the Earth. The mass in the KB is estimated as 2% of Earth mass. Which means the KB is about 4 times the mass of the AB.
I.e. there is four times the mass, within almost seven thousand times the volume. The density in the Kuiper Belt is then some 1.75 thousand times lower than that of the Asteroid Belt - and that was already low in absolute terms. To hit anything with a spacecraft one would need careful aiming, planned months or years ahead. Or colossaly bad luck.
