What is the best method for electromagnetic propulsion?
The best method for electromagnetic propulsion to lift a 30 kg weight using a pulley system is an ordinary electric motor. The power required to lift the weight can be calculated using the formula P = mgh/t, where m is mass, g is gravitational acceleration, h is height, and t is time. For a height of 3 meters, the energy required is 883 joules, excluding friction. This method is efficient for the specified application and provides a clear solution for lifting weights using electromagnetic principles.
  • Understanding of basic physics concepts such as force, energy, and power.
  • Familiarity with electric motors and their operational principles.
  • Knowledge of the formula P = mgh/t for calculating power requirements.
  • Awareness of electromagnetic propulsion systems and their applications.
  • Research the efficiency of different types of electric motors for lifting applications.
  • Explore advanced electromagnetic propulsion technologies, such as ion thrusters and maglev systems.
  • Study the effects of friction in pulley systems and how to mitigate them.
  • Investigate the energy consumption and performance metrics of electric motors in various scenarios.
Engineers, physicists, and hobbyists interested in electromagnetic propulsion, electric motor applications, and energy-efficient lifting mechanisms.
Sameh soliman
I mean by the best the one that use the least energy to produce the grater force capable of carrying weights .
Say you have a pulley attached to a ceiling with height of 3 meters, around the pulley is a string that attached to a 30 kg weight and on the other side of the string you want to use electromagnetic propulsion to lift the weight up ... What method will you use and how much power will it use ?
You would need to specify what sort of forces and weights are involved. Things like this don't easily scale for different sizes - take a slot racing car and a F1 style electric car. An electromagnetic engine that's suitable for one purpose may be hopeless for another purpose.
As long as you can run tracks where you want to go...
https://en.wikipedia.org/wiki/Maglev
We need more detail to answer.
To propel a space probe, an ion thruster is used.
To propel a race car, an electric motor is used.
To propel protons in an accelerator, magnets are used.
Edit: Are you working on a SF story?
OK... I wasn't clear at all
How about winding the string around the shaft of an electric motor? Does an electric motor qualify as "electromagnetic propulsion"?
I would use an electric motor. Power requirements depend on how fast you want it raised. The formula is P=mgh/t and you will want to make it larger to account for friction in the pulley
Edit: beat by @phyzguy !
An ordinary electric motor is the best option.
It will take 3*30 kg*m or 883 n*m or 883 joules of energy to lift neglecting friction.
Can you do the rest? Do you know what a joule is? a watt?
That will do it ... Thanks
  • · Replies 61 ·
11K
  • · Replies 74 ·
9K
  • · Replies 42 ·
12K
  • · Replies 23 ·
