What is the best source for this star data? (M44 Beehive Cluster)
  • Context: High School
  • Thread starter Thread starter terado
    Data Source Star
The discussion revolves around obtaining specific astronomical data for the stars in the M44 Beehive Cluster, including parameters such as right ascension (RA), declination (Dec), distance, apparent magnitude, absolute magnitude, and spectrum. Participants explore various sources and methods for accessing this data, including databases and software tools.
  • Homework-related
  • Some participants suggest using astronomical databases like Simbad, Aladin, VizieR, and Gaia Archive for querying raw astrometric and photometric data, noting that derived parameters may be harder to find.
  • Others propose using Stellarium as a user-friendly option to obtain most of the required data, although it may be tedious for a large number of stars.
  • One participant mentions that Wikipedia contains much of the requested information, but questions the meaning of "the" spectrum from numerous sources.
  • Some participants recommend the Sloan Digital Sky Survey, although one notes that many bright stars may not be included in its datasets.
  • A participant shares a Python code snippet for querying Simbad, indicating it returned a large number of items, but emphasizes the need to determine which are actual members of the Beehive cluster.
  • Another participant suggests that if the user is unfamiliar with Python, querying Simbad directly through its web interface might be more straightforward.
Participants express a variety of methods and tools for obtaining the desired data, but there is no consensus on a single best source or method. Some participants agree on the utility of databases like Simbad and Gaia, while others highlight the limitations of certain tools or datasets.
Some participants mention challenges related to the learning curve of using databases and programming tools, as well as the difficulty in finding specific data or tutorials. There is also a discussion about the potential for chance associations in the data retrieved from queries.
Astronomy enthusiasts, researchers, and students interested in obtaining star data for the M44 Beehive Cluster may find this discussion helpful.
terado
TL;DR
what's the easiest way to get this star data?
Hi
I need the below data for the thousand or so stars in M44 the Beehive Cluster. What would be the easiest way to get this data?
Thank you.
RA, Dec, distance, apparent magnitude, absolute magnitude, spectrum
Astronomy news on Phys.org
Have you tried/are you familiar with astronomical databases? Simbad, Aladin, VizieR, Gaia Archive?
You can query them for raw astrometric and photometric data, but derived parameters are harder to come by. So you should be able to get RA, dec, apparent magnitudes in different bands - parallax (i.e. distance) probably best if you go to Gaia - for most objects in the designated area. But absolute magnitude and spectral type are unlikely to be listed. You can calculate the former from distance and apparent magnitude, though.
If you've never used these before, there's something of a learning curve to surmount. Look in their help sections, maybe search for some tutorials on youtube.
I would start with Stellarium, which is a free download (https://stellarium.org/). You just click on the stars you are interested in, and you will get everything you listed except the spectrum, although you will get the spectral type. I'm attaching a screenshot.
phyzguy said:
I would star with Stellarium
A bit tedious if one wants to do it for ~1k objects.
Even Wikipedia has all of that information, except spectrum. To be honest, I don't know what "the" spectrum from 1000 sources even means. You might find B-V, or the spectrum of some characteristic stars, but I think you will need to ponder what it is you want.
You might try the Sloan Digital Sky Survey
They provide a number of increasingly recent data sets which include spectra of over 4 million astronomical objects.
Thanks.
That learning curve is exactly the reason I'm asking here!!
I did find those databases (except for the Gaia Archive) but couldn't work out how to submit a simple query like "M44 and all its 'children' stars" or "all stars within x parsecs of the centre of M44". I also had trouble finding decent tutorials.
There are about 25 bright stars in the cluster. I've found detailed information on those. All I really need for the rest is RA, Dec and distance.
I tried that, but many of the stars are too bright to be included.
I just query Simbad using Python. The code snippet below should give you what you want. It returned 2162 items. It's going to be up to you to determine which ones are actually physical members of the Beehive cluster and which ones are chance associations.
Python:
import numpy as np
from astroquery.simbad import Simbad
import astropy.units as u
result_table = Simbad.query_region("m44", radius=0.8 * u.deg)
print(result_table)
Python:
import numpy as np
print(result_table)
Thank you!
I have never used Python or Astroquery before. Just to check .. there is no online method and I have to install Astroquery to be ably to query in this way?
If you haven't used Python, it's probably best to query Simbad directly from the web interface. Below is a screen shot of the query. It's the same basic syntax and returned the same list of 2162 objects.
Thank you!
That got me the data.
  • · Replies 0 ·
