What is the consequence of a very low number of teeth on a gear?
  • Thread starter Thread starter Factao
    Gear Teeth
The discussion revolves around the implications of using gears with a very low number of teeth, particularly in the context of small-scale gear design for applications such as 3D printing. Participants explore various factors including tooth strength, precision, torque, and the effects of undercutting on gear performance.
  • Some participants note that having too few teeth can lead to undercutting, which weakens the teeth of the gear.
  • Others mention that lightly loaded gears can tolerate undercutting, and catalog load ratings account for this issue.
  • A participant shares an experience of successfully designing a gear with six teeth without undercutting by using profile offset.
  • Concerns are raised about precision, with some participants suggesting that speed, torque, and MTBF specifications will determine the required precision for materials and manufacturing techniques.
  • One participant reformulates their question to inquire whether undercut gears can be as precise as conventional gears under similar conditions.
  • Several alternatives for increasing torque without sacrificing precision are proposed, including rewinding the motor, increasing motor voltage, or purchasing a pre-assembled servo with a gear train.
  • Participants discuss the trade-offs between size, strength, precision, and cost in gear design.
  • It is mentioned that undercut affects tooth strength, while precision impacts running smoothness, noise, and fatigue life at high speeds.
  • 3D printed plastic gears are noted to generally lack precision, but low-load and low-speed applications may allow for fewer teeth and profile offset design.
  • One participant points out that a small number of teeth reduces the number of teeth engaged at any one time, which should be considered in torque ratings.
Participants express differing views on the impact of undercutting on precision and strength, and there is no consensus on whether undercut gears can match the precision of conventional gears. The discussion remains unresolved regarding the best practices for gear design in low-load applications.
Participants have not specified all parameters related to speed, torque, and material properties, which may affect the conclusions drawn about gear performance.
Factao
TL;DR
I've got two gear, one with 10 teeth and one with 20 gear (despite the fact that I should avoid repetitive pair of teeth contact). Is there is any issue with using gear with that little amount of teeth?
As summarized, I've got these two gear, and another stage of 15:10. I need my gear box as small as possible, and I've never work on this scale with gear (the module is 0,9mm, so this is pretty small). I know that this question is very simple, but I did not find anything relevant on the web, so don't mind sending me on another topic or whatever that is related.
It depends. If a gear has too few teeth, the teeth are undercut, which weakens them. Lightly loaded gears can tolerate undercut. If you are using gears from a catalog, the catalog load ratings take any undercut into account.
I once designed a gear with six teeth and no undercut by using profile offset. It worked very well.
There is no precision issue?
The speed, torque and MTBF specifications will determine the precision required for the material and manufacturing technique employed. You have not yet specified those parameters.
I am 3D printing (FDM) my gears with PLA, so I am expecting a low torque, a low speed and a MTBF as considerable as the error margin. However, I could reformulate my question: If we consider the same manufacturing processus, material and similar usage condition, will a pair of undercuts gears be precise as a pair of more conventional gears?
I want to gear up the torque of a servo motor ,without reducing its precision, while saving space with smaller gear, despite the FDM precision default for small detail.
without reducing its precision = anti-backlash gears, precision (instrument) bearings, precision machining
while saving space with smaller gear = planetary gear train
Alternative-1: rewind the motor with larger wire to allow higher continuous current without overheating.
Drawbacks to Alternative-1:
  • This works only until you reach magnetic saturation in the motor
  • Must reduce motor Voltage to maintain same speed
Alternative-2: If duty cycle is low,
And needed torque increase is low,
And speed is Not critical,
Then Increase motor voltage
Alternative-3: Purchase a servo with the gear-train included as a pre-assembled unit.
Small, Strong, Precise, Cheap. Pick 2 (or maybe 3 if you're a magician)
http://emanual.robotis.com/docs/en/dxl/x/xl430-w250/#specificationsThis little beast is quite balanced for its price.
As for the gears, I understand, from your reply that undercut gear doesn't affect the precision more than normal one, unless I miss something.
Wow, sure is. I was going to suggest you try for the next larger torque rating but I see the price goes way up.
I'll defer to @jrmichler on that. He's a local expert in that part of the field and I am definitely not!
Cheers,
Tom
Well, thank you for this, I will massage him.
Undercut affects tooth strength. Precision affects running smoothness, noise, and fatigue life at high speeds. They are two different things. Here is an image showing an undercut gear meshing with a rack:
Undercut can be eliminated by redesigning the gear with profile offset, but that increases the sliding action when the gears mesh. Search undercut gears for more information.
3D printed plastic gears will not be precise. If your application is low load and low speed, then design for the fewest number of teeth and use profile offset to reduce/eliminate undercut. If you are designing with SolidWorks, there is a module available for designing gears that makes it easy to specify variables such as profile offset. It's Gearcalc or Geartrax or something like that. The high end gear design package is Kisssoft, but I don't know if it integrates with solid modelling packages.
Massage no, message yes. :smile:
Thank you for this.
I kind of forget how to set this tread as resolved... How do I do that?
One issue with a small number of teeth on a gear is the number of teeth engaged at anyone time is reduced, but this would be taken into account for the specified torque rating.
24K
  • · Replies 26 ·
23K
12K
