What is the difference between %# and % in printf
  • Thread starter Thread starter transgalactic
    Difference
4 replies · 3K views
transgalactic
printf ("Some different radixes: %d %x %o %#x %#o \n", 100, 100, 100, 100, 100);
%x shows 100 in hexadecimal basis
64
but %#x makes some memory address out of it
0x64what does the addition of # ?
http://en.wikipedia.org/wiki/printf
"#": Alternate form.
For 'g' and 'G', trailing zeros are not removed.
For 'f', 'F', 'e', 'E', 'g', 'G', the output always contains a decimal point.
For 'o', 'x', and 'X', a 0, 0x, and 0X, respectively, is prepended to non-zero numbers.
regarding this
"For 'o', 'x', and 'X', a 0, 0x, and 0X, respectively, is prepended to non-zero numbers."
X turns to hex basis and O to octal basis
i was told that when we add # it add 0X to the transformed basis number in hex basis
but in octal basis it adds 0
why??
"Used with o, x or X specifiers the value is preceeded with 0, 0x or 0X respectively for values different than zero."
for what values we have different added signs?
g is a small float number
the trail of zeros you mean
0.765000000 >>0.765
Prepending 0 -- like 0123 -- indeed causes a literal value to use octal basis.
Prepending 0x -- like 0x0123 -- causes a literal value to use hex basis.
As far as I know prepending x (x0123?) doesn't do anything. I could be wrong.
I assume the reason they prepend 0 in octal and 0x in hex is because in both cases they're trying to reproduce the string necessary in order to create a literal if you paste the value back into C directly.
I wouldn't worry too much about the %# badge, I don't think many people use it. I've personally actually never used it before in my life, when I want to prepend 0x I just, you know, prepend 0x...
I don't know exactly what they mean by "trailing zeroes". I'd suggest just trying it and seeing what happens if you're really curious.
Don't understand the question
