What is the difference between superposition and intersection?
50 replies · 8K views
phya
The spherical geometry thought that in the surface does not have the parallel line, actually this idea is wrong, should say: In the spherical surface does not have the straight line parallel line, but in the spherical surface has the curve parallel line.
Is very actually good about the curve parallel concept understood. If we acknowledge any thing own and oneself always parallel, then we can not but acknowledge that the curve and the curve are also parallel. For instance a straight line, it own and oneself is parallel. Similarly, a circle, it own and oneself is also parallel. Therefore the curve and the curve are may mutually parallel.
In the spherical surface, the latitude parallel is mutually parallel. Therefore may not remove the parallel postulation in the spherical surface.
What is the parallel essence? The parallel essence is the distance maintains invariable. The curve parallel definition is, if two curve's distances maintain invariable, then these two curves are parallel. In curve parallel, does not intersect was not equal to that is parallel.
Mathematics news on Phys.org
This is incorrect. Spherically geometry defines great circles (circles on the sphere whose center is the center of the sphere) as "straight lines".
If, by this, you mean that an object and itself are always parallel, I have said, in another of your threads, that this NOT true. An object and itself are NEVER paralllel.
Except for the equator a "line of latitude" is not a great circle and so is not a "line" in the sense of spherical geometry.
That is a very bad "essence". As I said, again, in another of your threads on this same subject, it is ONLY in Euclidean geometry that the set of points at a constant distance from a given line (and on one side of it) is a line at all.
Further, depending on exactly how you define "distance" between two sets, it is possible to have "equidistant" sets that intersect one another. Not intersecting seems to me to be much more the "essence" of "parallel" than does "equidistant".
Today I did not reply first your question, I ask a question again: If in the spherical surface the great-circle is the straight line, then on the circular conical surface, what is a straight line?
I don't know what you mean by "circular conical surface"; is that "cone"?
It's not obvious that there's a version of neutral geometry that is modeled by the surface of a cone.
You as if have not understood my meaning.
CRGreathouse said:
That's what I said -- I don't understand what you mean by "circular conical surface". Care to enlighten?
I ask a your question: A straight line own and is parallel?
What you wrote isn't a valid English sentence, let alone one conveying mathematical content. My guess is that you mean, "Is a line parallel to itself?". If that's the case, then the answer is no.
Sorry, my English is not good. My meaning is: Whether a straight line is parallel to oneself?
Yes, this is my meaning.
If has moving point a and moving point c, straight line B through a and c, the direction which a and c move is always vertical to B, and a and the c straight line's distance maintains invariable, then a and the c path is a parallel line, regardless of this path is a straight line, or is the curve.
phya said:
NO?
Why?
Because it's obvious?
For example, in coordinate geometry when trying to find the intersection of two lines, we need to consider 3 cases and that is if they are parallel (thus no solution) if they are not parallel (thus 1 solution) and if they are the same line (infinite solutions). Just saying the two lines are parallel doesn't distinguish between the two cases.
In spherical surface, given a line L and a point p outside L, there exists no line parallel to L passing through p. attention, here line is not a straight line.
Mentallic said:
I made a mistake, I actually shouldn't have made a post here.
I'm not getting into this argument again.
Regret
No, the parallel essence is the distance constant invariable, because the non-concentric circle does not intersect, but their each other is not parallel.
You had not understood. After being similar to Einstein's theory comes out, also many people did not understand.
In analytic geometry, we all know, as the slope of the line are parallel, if only a straight line, its slope is only one, so the line is parallel with himself.
No, that is not true. Two distinct lines are parallell if and only if they have the same slope, but a line is NOT parallel to itself. Saying that a line is parallel to itself contradicts the basic definition of "parallel" that they do not have any point in common.
You seem to be insisting on using "equidistant" for parallel in spite of repeated explanations of why the is NOT appropriate.
If has straight line parallel line A and B, in A infinite approaches B in the process, they always parallel, when they superpose in together time, they no longer were parallel? They certainly parallel,
You the understanding have the question to the definition, a body is not the intersection, the part intersection, the part does not intersect is intersects.
Does anyone other than me get the impression that the responses by phya are computer-generated? See ELIZA.
I just assumed phya has aspergers and is making assumptions about geometry without studying it seriously.
I'm expecting new thread entirely dedicated to the sixth and the seventh sides of the triangle. And what happens if they are parallel...
Anyway it looks like computer translated language, but not generated. Computers cannot be so... eh... insistent.
I get the impression that Phya's native tongue is not English and that he has difficulty constructing an intelligible sentence.
What bothers me more is his insistence that he is right and everyone else is wrong.
It would be so much easier if we only had to cope with one of those.
