What is the difference between water power and turbine power
6 replies · 2K views
Ballena Joseph
What is the difference between water power and turbine power? Do they have the same formula?
Water power is pressure x rate of flow ,
This is the power which is goes through a water turbine and turbine power is out put from that particular turbine ,and the turbine power will be always less than water power because of losses
It is a matter of semantics. Is a water wheel a turbine? If you say yes, then there is no difference. If you say no, then there is a difference. (I say yes.)
https://www.quora.com/What-is-the-difference-between-a-water-wheel-and-an-electrical-turbine
Some people might say that pressure washing is water power.
So it is all in how you define the words.
Nik_2213 said:
A turbine system needs a turbine. There are other ways of extracting work from a head / flow of water.
http://www.douglas-self.com/MUSEUM/museum.htm
( Bottom right, but be prepared to lose a lot of time to bemused browsing... )
Wow, that is a fun resource. Thanks for sharing. I think engineers of all kinds will enjoy browsing the very meny ways of generating power.
