What is the domain of ascsin(x+y)
  • Thread starter Thread starter Mahathepp
    Domain
The domain of the function ascsin(x+y) is defined by the range of the sine function, which outputs values between -1 and 1. Therefore, the valid inputs for ascsin(x+y) must satisfy the condition that x+y falls within this range. The output of the arcsine function is restricted to the interval [-π/2, π/2] to ensure that each input corresponds to a unique output, thus maintaining the function's integrity. Understanding the relationship between sine and its inverse is crucial for determining the domain without relying on formulas.
  • Understanding of inverse trigonometric functions
  • Basic knowledge of the sine function and its properties
  • Familiarity with the concept of function and its domain
  • Graphing skills for visualizing functions and their inverses
  • Study the properties of inverse trigonometric functions, focusing on arcsine
  • Learn how to determine the domain of other inverse functions, such as arccosine and arctangent
  • Explore graphical representations of sine and arcsine functions
  • Practice solving problems involving the domain of composite functions
Students studying calculus, mathematicians, educators teaching trigonometry, and anyone interested in understanding inverse functions and their domains.
Mahathepp
Hey
Try to figure out the way to find domain of the function ascsin (x+y) without using the formula can someone give the clue how I should start ? Always confuse about inverse of trigonometry function. Thanks in advance.
The sine function takes an angle as an input and gives out a number between -1 to 1 as an output. Therefore, what will its inverse take as inputs and outputs?
Thanks for your reply. :kI think that the donain should be in the interval. π/2 and -π/2. The thing is in order to be able to plot graph which shows the relation between x and y , I have absolutely no idea how I can do without formula. Can you give me some idea ?
I'll elaborate more. In this situation, we are calling x + y the "input" of the function. This means that, no matter what, x + y will be in the correct domain--i.e. it will be a valid input for the function.
It's necessary to look at what an inverse function means. But to do that, we have to be sure you know what a function is. A function is something that you give an input to, and it gives you an output. Sine is a function. We give it an angle, and it gives us a number between -1 and 1. The inverse of sine is arcsine, but what does that mean? In a sense, it means that arcsine "undoes" whatever sine does. Let's look at some concrete example that don't involve these functions first.
Consider the function "Reverse phone book". Yes, this is a function. Why? Because we give it an input, and it assigns the input exactly one output. I give it the number 555-5555, and it outputs the name "John Smith". What would the inverse function look like? It would just be "phone book". I give it a name (John Smith), and it outputs a number (555-5555). (there is a complication with using this analogy--just assume for now that there are no repeated names in the book, and it will not be important for now).
So let's apply the same logic to sine. Sine takes in an angle, and it gives us a number between -1 and 1. So applying our logic, we see that the inverse function (arcsine) should take in a number between -1 and 1, and it should output an angle. The domain is just another name for the "list of valid inputs", so by extension right here, what's the domain?
Note: We limit the output to numbers between -pi/2 and pi/2, because otherwise, each input would have an infinite number of different outputs, and that's a no-no for functions.
Ohhh thank you so much ..I know now how it should be. . You are awesome. ! :k
  • · Replies 17 ·
