What Is the Energy Difference Between Octane and Methanol as Fuel Alternatives?
  • Thread starter Thread starter sciencenerd
Octane and methanol are compared as fuel alternatives based on their energy output per gram. Octane produces 48.1 kJ/g, while methanol yields approximately 19.96 kJ/g after conversion from kJ/mol. Considering the efficiency of combustion, octane operates at 30% efficiency and methanol at 40%. The calculations show that octane has a higher energy density, requiring a smaller tank for the same mileage compared to methanol. This highlights octane's advantage in energy storage per unit volume over methanol.
sciencenerd
gasoline/energy question...PLEASE HELP!
This is one of the problems i have to do...COMPLETELY LOST on it. I don't even know where to start or what to do. Please, please, please could someone help??
One of the serious problems that we have not yet solved is the use of fossil fuels, especially gasoline, to power our automobiles. Companies around the world are constantly trying to find a suitable replacement for gasoline. If we use octane (C8H18) as the representative of what is contained in gasoline, and compare it to methanol (CH3OH), currently a promising substitute for gasoline, what will be the energy difference on a per gram basis for the two. For the reaction of octane with oxygen to produce carbon dioxide and water, 48.1 kJ of heat are evolved per gram of octane burned. For the reaction ofmethanol, CH3OH, with oxygen to produce CO2 and gaseous water, 638.6 kJ/mole methanol. On a per gram basis, from which one will more energy be produced. The density of octane is 0.7025 g/cm3 and the density of methanol is 0.7914 g/cm3. If burning octane in an automobile is 30% efficient (i.e., 30% of the energy produced is used to move the car) and burning methanol is 40% efficient, which fuel will have the larger tank to have the same mileage capability?
a good place to start is molecular weight
MW octane = 8*12+18 = 114
MW methanol = 12+3+16+1 = 32
For octane, the energy produced is 48.1 KJ/g (given)
For methanol, the energy produced is 638.6 KJ/mol (given). To convert this to KJ/g, divide by MW of methanol. Then, 638.6/32 = 19.96 KJ/g
for octane:
48.1 KJ/g * 0.7025 g/cm^3 = 33.79 KJ/cm^3 * (0.3) = 10.137 KJ/cm^3 utilized energy
for methanol:
19.96 KJ/g * 0.7914 g/cm^3 = 15.8 KJ/cm^3 * (0.4) = 6.32 KJ/cm^3 utilized energy
More energy is stored in octane per unit volume than in methanol, thus methanol will require a larger tank.
I though gasolene was mostly toluene; the octane specification has to do with anti-knock properties of the engine.
thanks so much! it makes so much more sense when i actually see it done out :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
