What is the energy loss of a solid sphere hitting a wall obliquely?
  • Context: Graduate
  • Thread starter Thread starter physmurf
    Energy Momentum
The discussion focuses on calculating the energy loss of a solid sphere, approximately 0.5 mm in diameter, when it collides obliquely with a solid wall. Key parameters include tangential and normal velocities, as well as restitution coefficients. The conservation of energy and momentum principles are essential for deriving the energy loss formula. Participants seek clarity on additional parameters required for accurate calculations and references for further reading.
  • Understanding of conservation of energy and momentum principles
  • Familiarity with restitution coefficients in collision physics
  • Knowledge of basic kinematics, including tangential and normal velocities
  • Basic understanding of solid mechanics and material properties
  • Research the derivation of energy loss formulas in elastic and inelastic collisions
  • Explore the concept of restitution coefficients and their application in collision analysis
  • Learn about the impact of material properties on collision outcomes
  • Investigate numerical methods for simulating collisions in physics
Physics students, mechanical engineers, and anyone involved in collision analysis or material impact studies will benefit from this discussion.
physmurf
So, I am reading about a compton scattering problem, and I don't understand part of the derivation of a formula. I will explain my confusion.
If a gamma photon with energy [tex]E_{\gamma}[/tex], undergoes compton scattering with an electron which is at rest, how does one arrive at the following expression?
[tex]E^{'}_{\gamma}=\frac{E_{\gamma}}{1+(2E_{\gamma}/m_{o}c^{2})}[/tex]
So far it says we start with the conservation of energy and momentum:
[tex]E_{\gamma}=E^{'}_{\gamma}+E_{e} \ \ (eqn 1)[/tex]
[tex]\frac{E_{\gamma}}c=P_{e}-\frac{E^{'}_{\gamma}}{c}\ \ (eqn 2)[/tex]
From eqn 2 we get:
[tex]E_{\gamma}+E^{'}_{\gamma}=p_{e}c=\sqrt{(E_{e}+m_{o}c^{2})^{2}-(m_{o}c^{2})^{2}}[/tex]
This is where I am confused. I don't understand where the term inside of the radical comes from. Any ideas?
The [itex]E_e[/itex] in the square root on the right is the electron's kinetic energy, which most books call [itex]K_e[/itex]. [itex]E_e[/itex] usually means the total energy:
[tex]E_e = K_e + m_0 c^2[/tex]
Using this notation, the relationship between energy, momentum and mass is
[tex]E^2 = (pc)^2 + (m_0 c^2)^2[/tex]
so
[tex]p_e c = \sqrt {E_e^2 - (m_0 c^2)^2} = \sqrt {(K_e + m_0 c^2)^2 - (m_0 c^2)^2}[/tex]
hi all,
a similar post for me. pls help me.
i need to calculate the energy lost by a solid sphere (~ 0.5 mm dia) on hitting the solid wall obliquely.
i know the tangetial and normal velocities and the restitution coefficients. what other parameters do i need to know ??
help with the expression or a reference to articles in the web would be of great help.
thanks you.
  • · Replies 0 ·
