What is the final section the spinning wheel stops on at a county fair game?
  • Thread starter Thread starter eiriyuki
    Spinning Wheel
The problem involves a spinning wheel game at a county fair, where the wheel is divided into twelve sections, each representing an angle of 30 degrees. The task is to determine the section on which the wheel stops after deceleration from given initial angular velocities.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply kinematic equations to find the final position of the wheel based on initial angular velocities and deceleration. Some participants provide information on converting revolutions to degrees, while others suggest methods for determining the final section on the wheel.
Participants are exploring different methods for converting revolutions to degrees and identifying the corresponding section on the wheel. There is ongoing discussion about the correctness of the calculations and the conversion process, with no clear consensus reached yet.
The original poster expresses uncertainty about the accuracy of their calculations and the conversion from revolutions to degrees. There is a focus on ensuring the correct identification of the stopping section on the wheel based on the calculated revolutions.
eiriyuki
1. At a county fair there is a betting game that involves a spinning wheel. As the drawing shows, the wheel is set into rotational motion with the beginning of the angular section labeled "1" at the marker at the top of the wheel. The wheel then decelerates and eventually comes to a halt on one of the numbered sections. The wheel in the drawing is divided into twelve sections, each of which is an angle of 30˚. Determine the numbered section on which the wheel comes to a halt when the deceleration of the wheel has a magnitude of 0.355 rev/s2 and the initial angular velocity is (a) +1.61 rev/s and (b) +3.17 rev/s.
http://edugen.wiley.com/edugen/courses/crs2216/art/qb/qu/c08/qu_8_32.gif
I tried using equation \omega_{2} = \omega^{2}_{o} + 2\alpha\theta
I used 0 is omega final, +1.61 (a), and +3.17(b) are omega initials, alpha is 0.355, and theta is my unknown.
For part a, I got 3.65 revolutions and part B I got 14.15 revolutions. I do not know if this is correct so far, but I do not know how to convert from revolutions to degrees.
One revolution is 360 degrees.
Thank you!
However, I did not get the right answer when I converted my answers to degrees and then found the respective spot on the wheel.
To do this, I found subtracted 360 from my answer until I got a number below 360. Then I when by 30's from left to right (counter-clockwise) on the wheel until I landed in the respective box.
Any help with an error please?
ω = 2*π*f, where f is revolution per second. Try this one to find θ.
