What is the final velocity and direction of motion?
The final velocity of the spaceship, after being subjected to a force of -8.0 x 10^8 N for 10 seconds, is calculated to be 2.6 x 10^4 m/s in the original direction of motion. The initial velocity was 3.0 x 10^4 m/s, and the change in momentum was determined using the formula: Change in momentum = Force x Time. The correct application of the negative force indicates that the spaceship continues to move in the same direction, despite the opposing force acting on it.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with momentum and impulse concepts
  • Basic algebra for solving equations
  • Knowledge of vector direction in physics
  • Study the implications of negative forces in motion analysis
  • Learn about impulse-momentum theorem applications
  • Explore advanced topics in dynamics, such as collision theory
  • Investigate real-world applications of momentum conservation in spacecraft navigation
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of motion and momentum in the context of forces acting on objects.
looi76
A spaceship of mass 2000000kg is moving with a constant velocity of 3.0 \times 10^4 ms^{-1}. It is suddenly hit by a mysterious force of 8.0 \times 10^{10}N for 10s in the opposite direction to its motion. What is the final velocity and direction of motion?
Force = \frac{Change \ in \ momentum}{Time}
m = 2000000kg \ , \ u = 3.0 \times 10^4 ms^{-1} \ , \ F = 8.0 \times 10^8 \ , \ t = 10s
Change \ in \ momentum = Force \times Time
mv - mu = F \times t
2000000 \times v - 2000000 \times 3.0 \times 10^4 = 8.0 \times 10^8 \times 10
2000000v = 8.0 \times 10^8 \times 10 + 2000000 \times 3.0 \times 10^4
v = \frac{8.0 \times 10^8 \times 10 + 2000000 \times 3.0 \times 10^4}{<br /> 2000000}
v = 3.4 \times 10^4 ms^{-1}
and the direction of motion is in the opposite direction because momentum after collision is greater then momentum before collision.
Are my answers correct?
Notice that the force acts in the opposite direction to the motion. Therefore, if you chose your initial velocity to be positive, then the force must be negative.
\mbox{Change in momentum = Final momentum - Initial momentum}
m = 2000000kg \ , \ v = 3.4 \times 10^4 ms^{-1} \ , \ u = 3.0 \times 10^4 ms^{-1}
= mv - mu
= 2000000 \times 3.4 \times 10^4 - 2000000 \times (-3.0 \times 10^4)
= 1.28 \times 10^{11} N
Is this right?
I'm getting a positive momentum, so it is in the same direction?
= mv - mu
Is this right?
I don't think you understand what I'm getting at. In reference to my previous post,
This means that,
looi76 said:
F = 8.0 \times 10^8
Should actually be F = -8.0x108 N.
Do you follow?
Understood, velocity should be negative because the force is negative because it is in the opposite direction. So, the spaceship will move in the same direction?
looi76, you need to re-work your solution with the negative value for the force. You're answer is wrong as it stands.
Thnx Hootenanny,
m = 2000000kg \ , \ u = 3.0 \times 10^4 ms^{-1} \ , \ F = -8.0 \times 10^8 \ , \ t = 10s
2000000 \times v - 2000000 \times 3.0 \times 10^4 = -8.0 \times 10^8 \times 10
2000000v = -8.0 \times 10^8 \times 10 + 2000000 \times 3.0 \times 10^4
v = \frac{-8.0 \times 10^8 \times 10 + 2000000 \times 3.0 \times 10^4}{<br /> 2000000}
v = 2.6 \times 10^4 ms^{-1}
Change \ in \ momentum = mv-mu
= 2000000 \times 2.6 \times 10^4 - 2000000 \times -(3.0 \times 10^4)
= 1.1 \times 10^{11} N
I've not checked your arithmetic, but your method looks better :approve:
= 2000000 \times 2.6 \times 10^4 - 2000000 \times {\color{red}-}(3.0 \times 10^4)
I don't know why your calculating this, the final velocity gives you all the information you require. Eitherway, the intial velocity should be positive (you need to remove the highlighted negative sign). Note that your change in momentum should be identical to the impulse.
