What Is the Force of the Trout on the Carp in This Physics Problem?
  • Thread starter Thread starter Grapz
    Rope Tension
The problem involves two fish, a 3.0 kg trout and a 1.5 kg carp, connected by a line, with a force of 60 N applied upward on the carp. Participants are exploring the forces acting on the trout and carp system, particularly the force exerted by the trout on the carp.
  • Participants discuss free body diagrams for both fish, considering applied forces and gravitational forces. There are attempts to calculate net forces and tensions in the rope, with some participants questioning the assumptions made in their calculations.
There is ongoing exploration of the relationships between forces, with some participants providing calculations and others questioning specific steps. Guidance has been offered regarding the interpretation of forces and the role of gravity in the system.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made. There is uncertainty regarding the correct application of formulas and the interpretation of forces acting on the trout.
Grapz
Jimmy has caught two fish in Yellow Creek. He has tied the line holding the 3.0 kg steelhead trout to the tail of the 1.5 kg carp. To show the fish to a friend, he lifts upward on the carp with a force of 60 N. What is the force of the trout on the carp?
F_a on b = - F_b on a
Fnet = ma
So i draw the free body diagrams. I draw one for the carp, and i have The applied force of 60 N upwards, and force of gravity and F_carp on trout both are downwards.
I do Fnet = 60 / 4.5 = a = 13.333
then i do Fnet for the trout = 60 - mg - F_carp on trout = 3(13.333)
I get that F_carp on trout is = -9.39
BUT i test my answer out by drawing the free body diagram for the carp. Which should have two forces on it, the force of the trout on the carp which is equal but opposite of F carp on trout, points upwards, and gravity pointing downards.
So i do Fnet carp = F_trout on carp - mg = 1.5 ( 13.333)
If i sub in the numbers, 9.39 - (1.5)(9.8), i don't end up with (1.5)(13.333)
Can someone tell me what id id wrong, thanks
EDIT: I think i know what's wrong, my fbd is wrong
well, F= (m1 + m2)(g + a) , where F is the force with which the fisherman lifts up on the system and m1 & m2 are the masses of the carp and trout. Thus the acceleration of the whole system is given by a = F/(m1+m2) - g = 60/4.5 - 9.8 = 3.5333333 m/s^2.
The tension in the rope is then the force required for the trout to achieve this acceleration. Using F = ma, we get T = 3 x 3.533333 = 10.6 N , which is equal to the force of the carp on the trout. The force of the trout on the carp is just the opposite of this, -10.6 N.
i had trouble locating an exact error in your formulation, but i hope this helps.
Why is the acceleration of the whole system a = f / (m1 + m2) - g
i don't get the - g part :/
This is just a rearrangement of the formula F = m(g + a) , which is just a standard equation for the force required to accelerate a mass in a direction opposite gravity. In this case m is the combined mass of the two fish.
Step by step : F = m(g+a) ==> F/m = g+a ==> a = F/m - g
I see, can someone show me the free body diagram of the two fish?
i can draw up some quick schematics in paint if you like, but there should be an upward arrow representing the force with which the fisherman pulls upward, a downward arrow representing the weight of the two fish, and two equal and opposite arrows representing the forces the two fish exert on each other. The first arrow represents a force of 60 N; the second, 44.1 N (= weight of the fish); third and fourth = +/- 10.6 N.
ahhhh
thank you i get it noww
I have another question :x. The acceleration of the whole system is 3.5333, that i agree. The calculation for T = 3x 3.5333 is the part i am not too sure about. Indeed the net force is 10.6 N. But i do not think tension is the only force acting on the trout. There has to be gravity acting downwards. So then it must be T - mg = 3x3.53333. So T = 3x.3.533333 + 3x9.8 = 40
so then tension is 40
You are correct.
