What is the 'formal' definition for Total Derivative?
The total derivative is defined as dU = (dU/dx)dx + (dU/dy)dy + (dU/dz)dz, where the terms in parentheses represent partial derivatives. This equation arises from differential geometry, where dU acts as an operator that computes the rate of change of a function U along a vector V. The directional derivative of U along V is expressed as dU(V) = (∂U/∂x)V^x + (∂U/∂y)V^y + (∂U/∂z)V^z. In this context, the basis one-forms dx, dy, dz are treated as operators rather than infinitesimal changes.
  • Understanding of partial derivatives and their notation
  • Familiarity with differential geometry concepts
  • Knowledge of vector calculus and directional derivatives
  • Basic comprehension of parametrized paths and tangent vectors
  • Study the properties of directional derivatives in vector calculus
  • Explore the applications of total derivatives in differential geometry
  • Learn about the relationship between one-forms and differential operators
  • Investigate the implications of parametrized paths in multivariable calculus
Mathematicians, physicists, and engineering students who are studying multivariable calculus, differential geometry, or any field that requires an understanding of derivatives in multiple dimensions.
SebastianRM
A total derivative dU = (dU/dx)dx + (dU/dy)dy + (dU/dz)dz. I am unsure of how to use latex in the text boxes; so the terms in parenthesis should describe partial differentiations.
My question is, where does this equation comes from?
There are several slightly different ways to interpret differentials such as ##dU##. In differential geometry, one meaning of ##dU## is that it is an operator that takes a vector ##V## and returns the rate of change of ##U## as you travel along direction ##V##.
A little more detail: A parametrized path through space is a function that given a value of the path parameter ##s## returns a point in space. With coordinates ##x, y, z##, this path can be described by three functions, ##x(s), y(s), z(s)##. The "tangent vector" to the path is what would be called "velocity" if the parameter ##s## were time: ##\frac{d\mathcal{P}}{ds} = V## where ##V## has components ##V^x = \frac{dx}{ds}##, ##V^y = \frac{dy}{ds}##, ##V^z = \frac{dz}{ds}##. The rate of change of ##U## as you follow path is given by:
##\frac{dU}{ds} = \frac{\partial U}{\partial x} V^x + \frac{\partial U}{\partial y} V^y + \frac{\partial U}{\partial z} V^z##
which is also called the "directional derivative" along ##V##.
The total derivative ##dU## is an operator which given a vector ##V## returns the directional derivative of ##U## along ##V##:
##dU(V) = \frac{\partial U}{\partial x} V^x + \frac{\partial U}{\partial y} V^y + \frac{\partial U}{\partial z} V^z##
The basis one-forms ##dx, dy, dz## in differential geometry don't mean what they mean in calculus, which would be an infinitesimal change in ##x, y, z##/. Instead, they are viewed as operators themselves, with the sort of trivial definition:
##dx(V) = V^x##
##dy(V) = V^y##
##dz(V) = V^z##
So ##dx## for example, is the special case of ##dU## where ##U(x,y,z) = x##
Likes SebastianRM
  • · Replies 28 ·
  • · Replies 48 ·
  • · Replies 22 ·
