What is the formula to find inertia with velocity and mass?
The discussion centers on calculating inertia using velocity and mass, specifically with values of velocity at 2 m/s and mass at 10 kg. Participants clarify that inertia is not calculated directly from velocity and mass, but rather is a property related to mass. The confusion arises from mixing up inertia with momentum, which are distinct concepts. The key takeaway is that inertia is fundamentally linked to mass, and the more mass an object has, the greater its inertia.
  • Understanding of basic physics concepts such as inertia and momentum
  • Familiarity with the definitions of mass and its relationship to inertia
  • Knowledge of the formula for calculating momentum (p = mv)
  • Awareness of the concept of Moment of Inertia in rotational dynamics
  • Research the concept of Moment of Inertia and its applications in rotational motion
  • Study the differences between inertia and momentum in physics
  • Explore how mass affects inertia and the implications in real-world scenarios
  • Learn about the role of unbalanced forces in changing an object's state of motion
Students studying physics, educators teaching mechanics, and anyone seeking to clarify the concepts of inertia and momentum in physical systems.
Megan1000
v=2m/s
m=10kg
find the inertia
At first i did 2m/s times by 10kg which is 20 but i also did 2m/s divided by 10kg =0.2 and 10kg divided by 2m/s= 5 but I'm unsure which method is correct.
and momentum apparently isn't the same as inertia...
Inertia is when an object carries on doing the same thing unless an unbalanced force is acting on it!
Hi Megan1000,
Welcome to Physics Forums.
Megan1000 said:
v=2m/s
m=10kg
find the inertia
Note that you need to fill out the entire template and show what you've tried in order to solve the problem, or at least explain your understanding of it so far. Helpers are not permitted to offer any guidance otherwise.
Can you explain what you mean by "inertia"? Is it a term that is defined in your course notes or course textbook? Perhaps you meant "momentum"?
gneill said:
Hi Megan1000,
Welcome to Physics Forums.Note that you need to fill out the entire template and show what you've tried in order to solve the problem, or at least explain your understanding of it so far. Helpers are not permitted to offer any guidance otherwise.
at first i did 2m/s times by 10kg which is 20 but i also did 2 divided by 10 =0.2 and 10 divided by 2= 5 but I'm unsure which method is correct.
Inertia is this property, which is talked about, but rarely used in calculations (except when referring to Moment of Inertia, for objects which rotate).
Being that inertia is resistance to change in motion, the closest thing to inertia, is the mass of the object.
If you meant something different, then please clarify the problem statement.
so what should i use instead then?
never mind ...
the question wanted me to work out the order from smallest to greatest inertia and it gave me more things like the first thing i showed.
it gave me the mass, and the more mass you have the more inertia you have. so i put them in order of smallest to largest mass.
lol
thanks anyways x
Next time please post the problem statement word for word using the template. This is to avoid helpers wasting time trying to guess the real question.
  • · Replies 40 ·
14K
  • · Replies 19 ·
  • · Replies 66 ·
