What is the formula to find inertia with velocity and mass?
The discussion revolves around calculating inertia using given values of velocity (v=2 m/s) and mass (m=10 kg). Participants clarify that inertia is not directly calculated from velocity and mass, as it is a property related to an object's resistance to changes in motion. The confusion arises from mixing up inertia with momentum, which are distinct concepts. It is emphasized that mass is a key factor in determining inertia, and the correct approach involves understanding these definitions rather than performing arithmetic operations with the given values. The importance of clearly stating the problem and using the correct terminology in physics discussions is also highlighted.
Megan1000
v=2m/s
m=10kg
find the inertia
At first i did 2m/s times by 10kg which is 20 but i also did 2m/s divided by 10kg =0.2 and 10kg divided by 2m/s= 5 but I'm unsure which method is correct.
and momentum apparently isn't the same as inertia...
Inertia is when an object carries on doing the same thing unless an unbalanced force is acting on it!
Hi Megan1000,
Welcome to Physics Forums.
Megan1000 said:
v=2m/s
m=10kg
find the inertia
Note that you need to fill out the entire template and show what you've tried in order to solve the problem, or at least explain your understanding of it so far. Helpers are not permitted to offer any guidance otherwise.
Can you explain what you mean by "inertia"? Is it a term that is defined in your course notes or course textbook? Perhaps you meant "momentum"?
gneill said:
Hi Megan1000,
Welcome to Physics Forums.Note that you need to fill out the entire template and show what you've tried in order to solve the problem, or at least explain your understanding of it so far. Helpers are not permitted to offer any guidance otherwise.
at first i did 2m/s times by 10kg which is 20 but i also did 2 divided by 10 =0.2 and 10 divided by 2= 5 but I'm unsure which method is correct.
Inertia is this property, which is talked about, but rarely used in calculations (except when referring to Moment of Inertia, for objects which rotate).
Being that inertia is resistance to change in motion, the closest thing to inertia, is the mass of the object.
If you meant something different, then please clarify the problem statement.
Likes Megan1000
so what should i use instead then?
never mind ...
the question wanted me to work out the order from smallest to greatest inertia and it gave me more things like the first thing i showed.
it gave me the mass, and the more mass you have the more inertia you have. so i put them in order of smallest to largest mass.
lol
thanks anyways x
Next time please post the problem statement word for word using the template. This is to avoid helpers wasting time trying to guess the real question.
