What is the function of Switchgear in Substation?
  • Thread starter Thread starter tipu_sultan
    Function
The primary function of switchgear in substations is to provide automated fault protection, manual switching of power lines, and safety conditions for equipment maintenance. Switchgear is installed immediately after the step-down transformer and before the breaker panel, facilitating the de-energization of services. It is designed to handle large currents and voltages, featuring robust insulation and mechanical components for effective switching. Understanding the role of switchgear is essential for anyone involved in power engineering and substation operations.
  • Understanding of electrical engineering principles
  • Familiarity with substation components, including transformers and breaker panels
  • Knowledge of high voltage (HV) power systems
  • Basic comprehension of electrical safety protocols
  • Research "substation single line diagrams" for visual understanding of configurations
  • Study "automated fault protection systems" in electrical engineering
  • Learn about "high voltage switchgear specifications and standards"
  • Explore "maintenance procedures for switchgear in substations"
This discussion is beneficial for electrical engineers, power system designers, and maintenance personnel involved in substation operations and safety protocols.
tipu_sultan
I think its main function is to reduce arc flash.
But I want to know how it is connect with the transformer before or after.
Can anyone explain it through the block diagram?
If HV power lines enter in the substation first it connect to which one and after that which one ? [Switch gear, Transformer].
Is the input and output voltage & current of switchgear remains the same?
tipu_sultan,
No member here on Physics Forums will spoon-feed knowledge to others. You must show some effort to find the answers first. Then, if you get confused, or don't understand some details, come here and ask. Members here are always ready and willing to help any true "searcher".
I suggest you open "Google" and enter the search terms "function of switchgear in substation" and begin your lessons.
Bobbywhy
Likes 2 people
I've worked on these. It's really just a simple switch. Electrically it's no different than a light switch in your home. It typically has more poles of course for 3 phase power. Some of them can also break the neutral line as well (4 pole single throw).
What sets it apart is that switch gears are designed for large currents and voltages. The conductors in the switch are larger so that they can handle larger currents. Insulation is more robust to account for higher voltages. They also have a gear action and springs for the actual switching. A switchgear either slams shut or slams open. They're loud. It can take a little muscle to open and close a big switchgear.
Switchgears are typically installed immediately after the step-down transformer and before the breaker panel in commercial, industrial, or distribution services. The switch allows you to completely deenergize a service for maintenance purposes.
Likes 1 person
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
25K
16K
  • · Replies 21 ·
  • · Replies 46 ·
  • · Replies 32 ·
