What is the height of the Willis Tower in Chicago based on changes in gravity?
  • Thread starter Thread starter math34
    Energy
The discussion revolves around determining the height of the Willis Tower in Chicago based on the changes in gravity measured by a gravimeter. The problem involves concepts from gravitational physics and requires understanding the relationship between gravitational acceleration and height above the Earth's surface.
  • Participants discuss the relationship between gravitational acceleration at different heights and potential energy changes. There are attempts to derive equations involving gravitational constants and the Earth's radius.
Participants are actively engaging with the problem, offering hints and corrections regarding the formulation of equations. Some suggest using approximations for simplification, while others question the inclusion of mass in the calculations. The discussion appears to be progressing with various interpretations being explored.
There is a focus on the assumption that the height of the building is small compared to the Earth's radius, which influences the mathematical approach taken. Participants also express uncertainty about the complexity of the equations and the relevance of certain terms.
math34
A sensitive gravimeter is carried to the top of Chicago’s Willis (formerly Sears) Tower, where its reading for the acceleration of gravity is 1.36 mm/s^2 lower than at street level.
Find the building's height, h=?
I started this problem with this:
g - g' = 0.00136 m/s^2
now find the change in potential energy of gravity:
GMm/(Radius of earth)^2 - GMm/(Radius of Earth + h)^2
using this we should be able to simplify but i am not getting too far from here, it is a bit messy and i am not getting too much to cancel out here...why?
can anyone help me out?
please and thank you!
OK.
You're finding the change in g, not gravitational PE.
OK, except that it should be only GM in the numerator, not GMm.
Assume that h is small enough compared to the Earth's radius that you can use a binomial expansion approximation.
Hint: (R + h)^2 = R^2(1 + h/R)^2; now take advantage of the fact that h/R << 1.
Look at [itex]\displaystyle \frac{1}{R^2}-\frac{1}{(R+h)^2}=\frac{(R+h)^2-R^2}{R^2(R+h)^2}[/itex]
The numerator of the expression on the right side of the equation is the difference of squares.
Factor that.
R > 6300 km. I doubt that the building is more than 1 km tall (≈5/8 mile).
why is m not included in the formula?
going off the rest you said:
Re = radius of Earth
GM/(Re)^2 - GM/(Re + h)^2
Gm[(Re + h)^2 - (Re)^2] /(Re)^2 (Re + h)^2
using this: (R + h)^2 = R^2(1 + h/R)^2
i reduce down to :
Gm [ h^2/Re^2 + 2h/Re] / Re^2
does this sound right? still seems like a lot going on
Factor that.
Did you cancel out GM?
Because you want the acceleration, not the force.
i reduce down to :
Looks good. Now get rid of higher order terms, like (h/Re)2. They are too small to worry about. (And that m should be M, the mass of the earth.)
You're on the right track. Keep going.
right. now i get :
2GMh/Re^3
and get with an answer of 441.4 meterswhich turns out to be the right answer, sweet. Thanks everyone!
  • · Replies 19 ·
  • · Replies 63 ·
  • · Replies 21 ·
  • · Replies 17 ·
