What is the initial projectile speed of the ball?
The problem involves a projectile motion scenario where a softball is pitched from a height of 3.0 ft. Participants are tasked with determining the initial speed of the ball, its speed at maximum height, and the maximum height itself, based on a stroboscopic plot of its position over time.
  • Participants discuss the time it takes for the ball to reach maximum height and question the appropriateness of using 1.25 seconds in calculations. There are attempts to clarify the relationship between the time to maximum height and the equations used for height and speed.
The discussion is ongoing, with participants providing guidance on the correct interpretation of time in relation to projectile motion. There is an exploration of different assumptions regarding initial speed and height, but no consensus has been reached on the correct approach to the problem.
Participants are navigating the constraints of the problem, including the initial height of the ball and the timing of its ascent, which are critical to solving the questions posed.
kappcity06
The pitcher in a slow-pitch softball game releases the ball at a point 3.0 ft above ground level. A stroboscopic plot of the position of the ball is shown in the figure below, where the readings are 0.25 s apart and the ball is released at t = 0. On the horizontal axis, x1 = 20 ft.
(a) What is the initial speed of the ball?
ft/s
(b) What is the speed of the ball at the instant it reaches its maximum height above ground level?
ft/s
(c) What is that maximum height?
ft
i tried to find part c first. since i know that time is equal to 1.25 seconds i used deltay=.5at^2
.5(32)(1.25)^2
25 feet
this did not work so I do not know what to do?
any one with any help. thaks
Why are you using t=1.25s in your calculation? That isn't the time it takes the ball to get to maximum height.
If you can answer (b), that will help you answer (c).
Dorothy
u=0 i think
Gib Z said:
u=0 i think
u can't be zero as the ball is pitched!
i am still not getting the answer. I also tried time as 1.25/2 but this is stil not right?
any one please
1.25/2 is the time to the maximum height. The equation you were using gives the change in height from where it started. Don't forget it was 3 ft above the ground when it was thrown. So if you want the total height above the ground you have to take that into account.
Does that help?
15K
  • · Replies 21 ·
  • · Replies 22 ·
