What is the issue with this Fortran recursion problem?
  • Context: Fortran
  • Thread starter Thread starter hassamu
    Fortran Recursion
The discussion revolves around a Fortran program that implements recursion to calculate factorials. Participants are exploring issues related to the correctness of the code, particularly focusing on the recursive function's behavior and potential mistakes in the implementation.
  • One participant notes that the recursive function may require a stack pointer to track values, but expresses confusion about this suggestion.
  • Another participant suggests changing the condition from "if(myNumber <= 0)" to "if(myNumber == 1)", arguing that the original condition is incorrect.
  • A different participant counters that the original condition is correct because factorial(0) is defined as 1, and changing it would lead to an infinite loop for 0 or negative values.
  • Concerns are raised about the lack of an IMPLICIT NONE statement, which could lead to implicit typing issues between the main program and the recursive function.
  • One participant mentions that using default integers may limit the range of values for elNumero, suggesting the use of a different KIND value for integers to handle larger numbers.
  • Another participant proposes reorganizing the code to include the recursive function within the main program using the CONTAINS statement.
Participants express differing opinions on the correctness of the condition in the recursive function and the necessity of certain coding practices, indicating that multiple competing views remain without consensus on the best approach.
Some participants highlight limitations related to implicit typing and the range of integer values, suggesting that these issues could affect the program's functionality but do not resolve them.
hassamu
Hi everybody.
I am learning Fortran on my own, and I started doing simple examples like factorials, iterations, and stuff like that.
The problem comes in recursion, I'm trying to run this simple factorial program using recursion, but the outcome is completely wrong.
I asked to an expert in Fortran, but he said that I need to implement a stack pointer in order to keep track of all the values of my function, but I didn't understand him , and he is no more available this time.
Can somebody point out my mistakes or make suggestions about my program?
Thank you
Code:
recursive function factorial(myNumber) result (temp)
integer temp, myNumber
if(myNumber<=0) then
        temp = 1
        return
else
        temp = myNumber*factorial(myNumber-1)
        return
end if
end function factorial
program recursiveFactorial
      integer elNumero, resultado
      resultado = 1
      elNumero = 0
      write(*,*) 'Enter a positive integer:'
      read(*,*) elNumero
      resultado=factorial(elNumero)
      write(*,*) 'X!=',resultado
end program recursiveFactorial
Technology news on Phys.org
hassamu said:
Hi everybody.
Thank you
Code:
        temp = 1
        return
else
        return
end if
      resultado = 1
      elNumero = 0
      read(*,*) elNumero
Caveat: I haven't done much Fortran for about a dozen years. Since you are getting some results, your compiler must adhere to the Fortran 90 (or later) standard. Recursion isn't supported in Fortran 77.
Here's a link to some recursion examples in Fortran 90: http://math.scu.edu/~dsmolars/ma60/notesforrec.html.
Your code looks OK to me except for one line in your recursive function. I would change this:
Code:
if(myNumber <= 0) then
to this:
Code:
if(myNumber == 1) then
hassamu said:
Hi everybody.
Thank you
Code:
        temp = 1
        return
else
        return
end if
      resultado = 1
      elNumero = 0
      read(*,*) elNumero
A problem here is that you have not used an IMPLICIT NONE statement in your program and function to turn off implicit typing. Here "factorial" in your main program is a real quantity, but it is an integer in your function. You need to have:
Code:
integer factorial
or
Code:
integer,external::factorial
in your main program.
But you should always have IMPLICT NONE in both your main program, and all subroutines.
Also, you don't mention what kind of problems you are having, but by using the default integer you are restricting yourself to only small values for elNumero (for example, up to 12 for my compiler). If you go past this limit you will not get the answer, you'll just get garbage. You can choose a different KIND value for the integer to extend the range of the integers; for example, for my compiler you could use:
Code:
integer(kind=8):: elNumero, resultado
and similarly for all the other integer declarations. (Your compiler may use a different number than 8. )
To see what the largest value is that your variable can hold, you could add as a temporary line:
Code:
 print*,'The largest number here is ',huge(resultado)
right before the END PROGRAM line. At some point, for very large numbers, you might want to consider changing your program variables from integers to reals.
Code:
to this:
Code:
No, that is wrong, because factorial 0 (written 0!) is 1.
Your modification would cause an infinite loop for an argument of 0
and for any negative value.
The original test is correct.
hassamu said:
Hi everybody.
Thank you
Code:
        temp = 1
        return
else
        return
end if
      resultado = 1
      elNumero = 0
      read(*,*) elNumero
You should reorganize your code thus:
Code:
      IMPLICIT NONE
      resultado = 1
      elNumero = 0
      read(*,*) elNumero
CONTAINS
        temp = 1
        return
else
        return
end if
My point was that it was silly to check for negative numbers. If the input value was 0 or 1, you could return 1 as a special case, but for values greater than 1, you could use recursion.
Code:
      IMPLICIT NONE
      resultado = 1
      elNumero = 0
      read(*,*) elNumero
CONTAINS
        temp = 1
        return
else
        return
end if
There is a problem with this code as well. If you pass a negative number to the factorial function, it will return 1, and that is incorrect.
It is necessary to test for negative numbers.
If the recursive routine is presented with a negative argument,
it will loop forever.
It is essential to have a test for negative.
Either there needs to be an error trap, or the routine returns a value, say 1.
If there is no test for zero, an infinite loop occurs when the
function is presented with a negative argument.
  • · Replies 62 ·
13K
