What is the maximum mass of rocks one can lift using a wheelbarrow PLEASE HELP
The discussion revolves around determining the maximum mass of rocks that can be lifted using a wheelbarrow, given specific parameters such as the force exerted by the user, the distance of the center of mass from the wheel, and the angle of the handle. The context is rooted in mechanics and involves concepts of torque and force equilibrium.
  • Participants discuss the application of torque equations and the relationship between the forces involved. There are attempts to set up equations based on the geometry of the situation, including the use of sine functions to resolve forces. Some participants express confusion about the calculations and the correct interpretation of the forces.
There are multiple approaches being explored, with participants offering different equations and interpretations of the problem. Some guidance has been provided regarding the setup of torque equations, but there is no explicit consensus on the correct method or final answer yet.
Participants are working within the constraints of the problem statement, including the maximum force the man can exert and the specific distances involved. There is an ongoing discussion about the correct application of trigonometric functions and the implications of the forces at play.
mhayer7
What is the maximum mass of rocks one can lift using a wheelbarrow PLEASE HELP!
A man is using a wheelbarrow to transport rocks across the garden. The man can generate a maximal vertical force of 500N to lift the wheelbarrow. If the centre of mass of the rocks is .25m horizontally from the wheel, and the handle of the wheelbarrow is 1.5m at an angle of 35 degress from the horizontal, what is the maximum mass of rocks he can lift?
sum or torques equation. f=ma, phythagorean theorem.
I tried drawing a diagram for this but ended up confusing myself. I know i need to use similar triangles to try and find the max weight since we have the force applied by the man but am not sure how to do it. I know it will be something like MASS OF ROCKS TIMES GRAVITY X .25M = 500N TIMES 1.5M. But I am very confused as to how to accomplish this. Any help is appreciated!
would this helps?
you should also put in mind the angle
hey mhayer7:smile:, you don't have to PM me, just post here and you'll get the help from me or others:wink:
did you try this;
sum of torques=0
Fmax[1.5]sin35o=F[0.25]sin35o
note that F here is the force applied on the wheel
hey drizzle,
so using your formula,
we wud end up with 500 which is the force applied by the man
500[1.5]sin35o/.25[sin35]= 3000 N
3000N / 9.81 = 305.8 kg's
i hope that's right
the 3000N you got isn't the weight of the rock!
read the note
sorry so if i did it like this
since i have 500 and sin 35 using that i can get the perpindicular force which is also the hypoteneuse . so sin35 = 500/z . z = 871.7 then plugging that into your equation
we get 871times 1.5 times sin35 = .25sin35 F
solving for F we get 5230.3
dividing that by 9.81 we get 533.2 kg
Is that right?
no, skip this last calculations you’ve done, what you’ve done previously was good so far [that is, with having 3000N as the force applied on the right side of the wheelbarrow -using Newton’s 3rd law-], now you should calculate the sum of vertical forces [this should equal to zero], then you’ll have the mass of the rock.
12K
9K
