What is the Missing Piece in Solving for ρ in this Simple Problem?
  • Thread starter MadMatSci
    Unknowns
8 replies · 3K views · last reply
MadMatSci
The total energy for a Van der Waals bonded solid is:
[itex]E=-\frac{A}{r^6}+B*e^{-\frac{r}{\rho}}[/itex]
where the 1st and 2nd terms are for attraction and repulsion respectively, A and B are constants, r is the inter-atomic distance, and [itex]\rho[/itex] is the range of interaction (i.e. characteristic length)
Given [itex]E=.9*E_{attr.}[/itex] and Eqm Spacing, [itex]r_o[/itex]= 1.5 angstroms, find [itex]\rho[/itex] in angstroms
The first piece of information, [itex]E=.9*E_{attr.}[/itex], gives me:
[itex]E=-\frac{A}{r^6}+B*e^{-\frac{r}{\rho}}=.9*E_{attr.}=.9*(-\frac{A}{r^6})[/itex]
Rearranging yields:
[itex].1*\frac{A}{r^6}=B*e^{\frac{-r}{\rho}}[/itex]
The second piece of information leads me to assume that at r=1.5 the derivative of the expression for total energy=0. This gives me the following equation:
[itex]6\frac{A}{1.5^7}=\frac{B}{\rho}e^{\frac{-1.5}{\rho}}[/itex]
From here I am confused. I first tried to solve [itex].1*\frac{A}{r^6}=B*e^{\frac{-r}{\rho}}[/itex] for A and then substitute that into [itex]6\frac{A}{1.5^7}=\frac{B}{\rho}e^{\frac{-1.5}{\rho}}[/itex].
Seeing no way out, I set the r's in the equation for A to 1.5. This led to:
[itex]\frac{60}{1.5}B*e^{\frac{-1.5}{\rho}}=\frac{B}{\rho}*e^{\frac{-1.5}{\rho}}[/itex] which leads to:
[itex]\rho=\frac{1.5}{60}=.025[/itex]
It does not seem valid to just sub in r=1.5. This was a shot in the dark as I am out of ideas.
I spoke to my instructor about this and how I did not see a way to solve for [itex]\rho[/itex] because it looks as though there are 2 equations and 3 unknowns. His response was that this is a simple problem and that I do not need to know the constants A and B. I must be over thinking this. Does anyone see what I am missing?
MadMatSci said:
I realize that is not correct.
I didn't check the numbers, but the approach is right.
The condition E=0.9 EAttr is satisfied at r0 only.
You have three unknowns for two equations, but it is neither possible nor necessary to find A and B separately. You can find the ratio A/B, as both equations depend on this and ρ only.
Wow. Thank you. I did not realize that E=.9 EAttr is valid at r0 only. I guess it does make sense though since at equilibrium it is possible to determine what fraction of the total energy is attractive and repulsive. Thanks again!
Why do you say that answer is clearly not correct? The method is sound, and I can see no numerical errors.
I did not think that I could just assume r=1.5. I thought it had to be valid for all r until mfb indicated otherwise.
The equation in question is valid for all r. In particular, it is valid at r=1.5 A.
Thank you very much for your help!
The equation that says the total energy is 90% of the attractive potential energy? No, that is not correct everywhere.
I'm fairly sure MadMatSci was referring to the general equation quoted first off: ##E=−\frac A{r^6}+B∗e^{−rρ}##. The value of 1.5 for r had already been substituted in the 90% equation.
