What is the Missing Piece in Solving for ρ in this Simple Problem?
  • Thread starter Thread starter MadMatSci
    Unknowns
The discussion revolves around a problem involving the total energy of a Van der Waals bonded solid, expressed in terms of inter-atomic distance and constants. The original poster attempts to find the characteristic length, ρ, given specific energy conditions and equilibrium spacing.
  • Exploratory, Assumption checking
  • Participants explore the relationship between total energy and its components, questioning the validity of substituting specific values for r. There is discussion about the number of unknowns relative to the equations available and the possibility of finding a ratio of constants rather than their individual values.
Some participants have provided guidance on the interpretation of the equations, noting that the condition for total energy being 90% of the attractive potential energy is valid only at the equilibrium distance. There is an acknowledgment of the original poster's confusion regarding the assumptions made in the problem.
There is a mention of the original poster's instructor suggesting that the problem is simpler than initially perceived, indicating a potential misunderstanding of the need for constants A and B. Participants also discuss the implications of the equations being valid for all values of r, particularly at the specified equilibrium distance.
MadMatSci
The total energy for a Van der Waals bonded solid is:
[itex]E=-\frac{A}{r^6}+B*e^{-\frac{r}{\rho}}[/itex]
where the 1st and 2nd terms are for attraction and repulsion respectively, A and B are constants, r is the inter-atomic distance, and [itex]\rho[/itex] is the range of interaction (i.e. characteristic length)
Given [itex]E=.9*E_{attr.}[/itex] and Eqm Spacing, [itex]r_o[/itex]= 1.5 angstroms, find [itex]\rho[/itex] in angstroms
The first piece of information, [itex]E=.9*E_{attr.}[/itex], gives me:
[itex]E=-\frac{A}{r^6}+B*e^{-\frac{r}{\rho}}=.9*E_{attr.}=.9*(-\frac{A}{r^6})[/itex]
Rearranging yields:
[itex].1*\frac{A}{r^6}=B*e^{\frac{-r}{\rho}}[/itex]
The second piece of information leads me to assume that at r=1.5 the derivative of the expression for total energy=0. This gives me the following equation:
[itex]6\frac{A}{1.5^7}=\frac{B}{\rho}e^{\frac{-1.5}{\rho}}[/itex]
From here I am confused. I first tried to solve [itex].1*\frac{A}{r^6}=B*e^{\frac{-r}{\rho}}[/itex] for A and then substitute that into [itex]6\frac{A}{1.5^7}=\frac{B}{\rho}e^{\frac{-1.5}{\rho}}[/itex].
Seeing no way out, I set the r's in the equation for A to 1.5. This led to:
[itex]\frac{60}{1.5}B*e^{\frac{-1.5}{\rho}}=\frac{B}{\rho}*e^{\frac{-1.5}{\rho}}[/itex] which leads to:
[itex]\rho=\frac{1.5}{60}=.025[/itex]
It does not seem valid to just sub in r=1.5. This was a shot in the dark as I am out of ideas.
I spoke to my instructor about this and how I did not see a way to solve for [itex]\rho[/itex] because it looks as though there are 2 equations and 3 unknowns. His response was that this is a simple problem and that I do not need to know the constants A and B. I must be over thinking this. Does anyone see what I am missing?
MadMatSci said:
I realize that is not correct.
I didn't check the numbers, but the approach is right.
The condition E=0.9 EAttr is satisfied at r0 only.
You have three unknowns for two equations, but it is neither possible nor necessary to find A and B separately. You can find the ratio A/B, as both equations depend on this and ρ only.
Wow. Thank you. I did not realize that E=.9 EAttr is valid at r0 only. I guess it does make sense though since at equilibrium it is possible to determine what fraction of the total energy is attractive and repulsive. Thanks again!
Why do you say that answer is clearly not correct? The method is sound, and I can see no numerical errors.
I did not think that I could just assume r=1.5. I thought it had to be valid for all r until mfb indicated otherwise.
The equation in question is valid for all r. In particular, it is valid at r=1.5 A.
Thank you very much for your help!
The equation that says the total energy is 90% of the attractive potential energy? No, that is not correct everywhere.
I'm fairly sure MadMatSci was referring to the general equation quoted first off: ##E=−\frac A{r^6}+B∗e^{−rρ}##. The value of 1.5 for r had already been substituted in the 90% equation.
  • · Replies 24 ·
