What is the moment of inertia of the pendulum
The moment of inertia of a pendulum consisting of a solid sphere, a bar, and a block, each with a mass of 4 kg, is calculated using the parallel axis theorem. The equations used include I(sphere) = (2mr^2)/5, I(bar) = (mL^2)/12, and I(block) = mr^2. The final calculation yields a moment of inertia of 124.6 r², confirming the correct application of the parallel axis theorem twice. The axis of rotation is positioned halfway between the top of the sphere and its center, specifically at R/2.
  • Understanding of moment of inertia concepts
  • Familiarity with the parallel axis theorem
  • Knowledge of basic physics equations related to rotational motion
  • Ability to perform calculations involving solid shapes and their mass distributions
  • Study the derivation of the parallel axis theorem in detail
  • Learn about the moment of inertia for different geometric shapes
  • Explore advanced applications of rotational dynamics in pendulum systems
  • Investigate the effects of varying mass distributions on moment of inertia calculations
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators teaching concepts related to moment of inertia and pendulum motion.
dazedy
A pendulum constructed of a solid sphere, bar, and block, each with mass m=4 kg
The sphere has radius R, The bar attaches the block and sphere and has length 2R, and the block has a center of mass R away from the end of the bar. The axis of rotation is halfway between the top of the sphere and its center (R/2)
What is the moment of inertia of the pendulum (note: you will need to use the parallel axis theorem twice!)
I = I(sphere) + I (bar) + I (block)
I(bar) = (mL^2)/12
I(block) = mr^2 (treat as point mass bc you know center of gravity)
Parallel axis theorem: Iaxis = Icm + mr^2
Should I simply solve for I, plugging in the equations above?
I = [(2mr^2)/5 + m(r/2)^2] + (m(2r)^2)+m(2.5r)^2 + m(4.5r)^2 = 124.6 r^2
Nevermind, figured the problem out.
  • · Replies 28 ·
  • · Replies 21 ·
