What is the Mystery Behind i^i? Unveiling the Intricacies of Euler's Formula
  • Context: Graduate
  • Thread starter Thread starter Max cohen
The discussion centers on the mathematical expression i^i, derived from Euler's formula e^{xi}=cos(x)+sin(x)i. Substituting x with \frac{\pi}{2} leads to the identity e^{\frac{\pi}{2}i}=i, and raising both sides to the power of i results in the real number i^i = e^{-\frac{\pi}{2}}. Participants clarify that while the principal value is e^{-\frac{\pi}{2}}, there are infinitely many values for i^i represented by the general form i^i = e^{-\frac{1}{2}(2k + 1)\pi}, where k is any integer. This highlights the multivalued nature of complex exponentiation.
  • Understanding of Euler's formula and complex numbers
  • Familiarity with complex exponentiation
  • Knowledge of logarithmic functions and their multivalued nature
  • Basic grasp of mathematical notation and identities
  • Explore the implications of complex exponentiation in advanced mathematics
  • Study the properties of logarithmic functions in complex analysis
  • Investigate the concept of multivalued functions in mathematics
  • Learn about the applications of Euler's formula in various mathematical fields
Mathematicians, students of advanced mathematics, and anyone interested in the complexities of complex numbers and their applications in theoretical contexts.
Max cohen
Take euler's formula for the identity of complex numbers:
If we substitute the value \pi for x it turns out that
e^{i\pi}=-1
most of us already knew this wonderfull trick.
BUT if we substitute \frac{\pi}{2} for x we get (because cos pi/2 = 0 and sin pi/2 = 1):
Now if you raise both sides of this identity to the power i, you obtain (since i^2 = -1):
e^{-\frac{\pi}{2}}=i^i
Calculating the value of e^{-\frac{\pi}{2}} it turns out that
i^i=0,2078795763...
Isn't that just the weirdest thing ever?? :confused:
It is a real number.And i wouldn't call anything in mathematics weird.
Daniel.
That's just the principal value. There are an infinite number of values for the expression i^i, all real.
The general form is given by :
i^i = e^{-\frac{1}{2}(2k + 1)\pi}, where k ranges over all integers. The principal value is for zero k.
are you sure of that formula? try k=1.
:-p
I think you mean:
i^i = e^{-\frac{1}{2}(k + 1)\pi}
since it works for every k*(pi/2) with zero k beeing the principal value if I'm correct
Nope.Compare the case k=0 and k=1,for simplicity.
Daniel.
I see... :shy:
Sorry, I was wrong. The general form should be i^i = e^{-\frac{1}{2}\pi(4k + 1)}.
dextercioby said:
Nope,it can't be that one.
Daniel.
Why not ?
k = 0, obvious.
k = 1, exp (-5pi/2) = z.
z^(-i) = exp(5*i*pi/2) = exp(i*pi/2 + 2*i*pi) = i
and so forth.
Alright
You said (see above)
i^{i}=e^{-\frac{1}{2}\pi(4k+1)}
I say
k=0 (1)
\mathbb{R}\ni i^{i}=e^{-\frac{\pi}{2}} (2)
k=1 (3)
\mathbb{R}\ni i^{i}=e^{-\frac{5\pi}{2}}\neq e^{-\frac{\pi}{2}}\substack{(2)\\\displaystyle{=}} i^{i}\in\mathbb{R} (4)
Do you see something fishy...? :rolleyes: You're working with very real numbers...No more multivalued functions...
Daniel.
Okay,now here's what u and Max Cohen wanted to write.
i^{i}=e^{-\frac{\pi}{2}+2ki\pi} \ ,\ k\in\mathbb{Z}
Daniel.
No, that's not what I wanted to write. I meant that i^i has an infinite number of real, distinct values as given by the general form. The form you wrote trivially gives only a single real value.
My first form was wrong because it generated values for (-i)^i as well. But this form is definitely right.
Complex exponentiation is multivalued, and yes, it can even give an infinite number of distinct real results.
Nope.Everything is in terms of real numbers.U use equality sign,and the reals have a funny way of behaving way when in the presence of the equality sign...
i^{i}=:a\in\mathbb{R}
You're telling me that a=e^{-\frac{\pi}{2}}=e^{-\frac{5\pi}{2}}=e^{-\frac{9\pi}{2}}=...
and that's profoundly incorrect.
Daniel.
This isn't what he's saying. He's saying that you have many different choices for i^i:=e^{i\log{i}}. log is a multivalued function, \log{i}=\pi i/2+2\pi i k for any integer k. The choice of k chooses the branch of log you are working with. So i^i=e^{i(\pi i/2+2\pi i k)}=e^{-\pi /2-2\pi k} and the different values of k give different values of i^i, depending on which branch of log you're using. e^{-\frac{\pi}{2}},e^{-\frac{5\pi}{2}},e^{-\frac{9\pi}{2}},\ldots are all valid answers for i^i, just as \pi i/2,5\pi i/2,9\pi i/2,\ldots are all valid answers for log(i).
^Exactly. :smile:
Alright.Point taken.:smile: I never thought of it this way before,so i have a reason to thank you.
Daniel.
Daniel.
Cool. :smile: Perhaps the orig. poster was not right when he said math is weird, but math certainly is beautiful and mysterious. ;)
"The arcane pleasures of abstruse maths is only for the select few of lofty intellect and weird speech patterns"
Was that what you meant?..:wink:
Oooh, I have goosebumps. LOL. :biggrin:
  • · Replies 16 ·
