What is the Nelder-Mead algorithm and how can it be implemented in pure Python?
  • Topic: Python
  • Thread starter Thread starter m4r35n357
    Pure Python
3 replies · 5K views · last reply
m4r35n357
Adapted from this code, which is an implementation of the algorithm described here.
Python:
from copy import copy
from sys import stderr, argv
def replace_worst(data, new):
    del data[-1]
    data.append(new)
def nelder_mead(f, x_0, x_δ, stuck_threshold=10e-12, stuck_break=10, max_iterations=0, α=1.0, γ=2.0, ρ=-0.5, σ=0.5):
    # initial simplex
    dim = len(x_0)
    assert dim == len(x_δ)
    dimensions = range(dim)
    prev_best = f(x_0)
    results = [[x_0, prev_best]]
    for i in dimensions:
        x = copy(x_0)
        x[i] += x_δ[i]
        score = f(x)
        results.append([x, score])
    iterations = no_improvement = nt = nr = ne = nc = ns = 0
    while True:
        nt += 1
        # 1. order
        results.sort(key=lambda z: z[1])
        best = results[0][1]
        # break after max_iter
        if max_iterations and iterations >= max_iterations:
            return results[0], nt - 1, nr, ne, nc, ns
        iterations += 1
        # break after no_improvement iterations with no improvement
        print('...best so far:', best, file=stderr)
        if best < prev_best - stuck_threshold:
            no_improvement = 0
            prev_best = best
        else:
            no_improvement += 1
        if no_improvement >= stuck_break:
        # 2. centroid
        x0 = [0.0] * dim
        for result in results[:-1]:
            for i, c in enumerate(result[0]):
                x0[i] += c / (len(results)-1)
        # 3. reflect
        xr = [x0[i] + α * (x0[i] - results[-1][0][i]) for i in dimensions]
        r_score = f(xr)
        if results[0][1] <= r_score < results[-2][1]:
            nr += 1
            replace_worst(results, [xr, r_score])
            continue
        # 4. expand
        if r_score < results[0][1]:
            xe = [x0[i] + γ * (x0[i] - results[-1][0][i]) for i in dimensions]
            e_score = f(xe)
            ne += 1
            replace_worst(results, [xe, e_score] if e_score < r_score else [xr, r_score])
            continue
        # 5. contract
        xc = [x0[i] + ρ * (x0[i] - results[-1][0][i]) for i in dimensions]
        c_score = f(xc)
        if c_score < results[-1][1]:
            nc += 1
            replace_worst(results, [xc, c_score])
            continue
        # 6. shrink
        x1 = results[0][0]
        reduced = []
        for result in results:
            xs = [x1[i] + σ * (result[0][i] - x1[i]) for i in dimensions]
            score = f(xs)
            ns += 1
            reduced.append([xs, score])
        results = reduced
if __name__ == "__main__":
    # Example: python NelderMead.py 3.0 3.0 0.1 0.1
    def himmelblau(z):
        x, y = z
        return (x ** 2 + y - 11) ** 2 + (x + y ** 2 - 7) ** 2
    print(nelder_mead(himmelblau, [float(argv[1]), float(argv[2])], [float(argv[3]), float(argv[4])]))
else:
    print(__name__ + " module loaded", file=stderr)
For working with large arrays, yes, but not in this case (Nelder-Mead fails with many dimensions). Pretty much all my work is "embarrassingly unparallellizable" (or something like that). In my case it is a colossal dependency that I never use. In practice, the list comprehensions and sums keep it compact. BTW I've refactored it for more type safety, better progress and result reporting, and easier understanding, first the test library:
Python:
from collections import namedtuple
Point = namedtuple('PointType', ['x', 'f'])
    del data[-1]
    data.append(new)
def nelder_mead(f, x_0, x_δ, ε=10e-12, stuck_break=100, max_iterations=1000, α=1.0, γ=2.0, ρ=-0.5, σ=0.5):
    dim = len(x_0)
    prev_best = f(x_0)
    simplex = [Point(x=x_0, f=prev_best)]
        x = copy(x_0)
        x[i] += x_δ[i]
        simplex.append(Point(x=x, f=f(x)))
    iterations = stuck_counter = nt = nr = ne = nc = ns = 0
    latest = ""
    while True:
        nt += 1
        simplex.sort(key=lambda z: z.f)
        best = simplex[0]
        worst = simplex[-1]
        second_worst = simplex[-2]
        best_value = best.f
        data = '{} {} {}'.format(iterations, simplex, latest)
        if best_value < prev_best:
            stuck_counter = 0
            prev_best = best_value
        else:
            stuck_counter += 1
        if stuck_counter >= stuck_break:
            raise RuntimeError("STUCK for {} steps! ".format(stuck_counter) + data)
            raise RuntimeError("UNFINISHED! " + data)
        print(data, file=stderr)
        if sum((best.x[i] - worst.x[i])**2 for i in dimensions) < ε and (best.f - worst.f)**2 < ε:
            return best, nt - 1, nr, ne, nc, ns
        iterations += 1
        centroid = [0.0] * dim
        for result in simplex[:-1]:
            for i, c in enumerate(result.x):
                centroid[i] += c / (len(simplex)-1)
        xr = [centroid[i] + α * (centroid[i] - worst.x[i]) for i in dimensions]
        r_score = f(xr)
        if best.f <= r_score < second_worst.f:
            nr += 1
            replace_worst(simplex, Point(x=xr, f=r_score))
            latest = "reflection"
            continue
        if r_score < best.f:
            xe = [centroid[i] + γ * (centroid[i] - worst.x[i]) for i in dimensions]
            e_score = f(xe)
            ne += 1
            replace_worst(simplex, Point(x=xe, f=e_score) if e_score < r_score else Point(x=xr, f=r_score))
            latest = "expansion" + ("(e)" if e_score < r_score else "(r)")
            continue
        xc = [centroid[i] + ρ * (centroid[i] - worst.x[i]) for i in dimensions]
        c_score = f(xc)
        if c_score < worst.f:
            nc += 1
            replace_worst(simplex, Point(x=xc, f=c_score))
            latest = "contraction"
            continue
        reduced = []
        for vertex in simplex[1:]:
            xs = [best.x[i] + σ * (vertex.x[i] - best.x[i]) for i in dimensions]
            ns += 1
            reduced.append(Point(x=xs, f=f(xs)))
        simplex = reduced
        latest = "reduction"print(__name__ + " module loaded", file=stderr)
and the test program:
Python:
from sys import argv
from NelderMead import nelder_mead
class Rosenbrock(object):
    def __init__(self, a, b):
        self.a = a
        self.b = b
    def func(self, z):
        x, y = z
        return (self.a - x)**2 + self.b * (y - x**2)**2
def himmelblau(z):
    x, y = z
    return (x**2 + y - 11)**2 + (x + y**2 - 7)**2
    # Example: python Rosenbrock.py -3.0 -3.0 0.1 0.1
    init = [float(argv[1]), float(argv[2])]
    deltas = [float(argv[3]), float(argv[4])]
    print(nelder_mead(Rosenbrock(1.0, 100.0).func, init, deltas))
    print(nelder_mead(himmelblau, init, deltas))
Found and fixed the "shrink/reduce" function which was not being exercised until now. Also refactored and significantly shortened. I think the termination code makes more sense now too.
BTW this minimal code is just a bit of fun for those who want to kick the tyres, learn and debug etc. without messy dependencies.
Python:
def nelder_mead(f, x_0, x_δ, ε, stuck_limit=100, limit=1000, α=1.0, γ=2.0, ρ=-0.5, σ=0.5):
    n = len(x_0)
    assert n == len(x_δ)
    dim = range(n)
    best = f(x_0)
    s = [[x_0, best]]
    for i in dim:
        v = [x for x in x_0]
        v[i] += x_δ[i]
        s.append([v, f(v)])
    count = stuck_count = nr = ne = nc = ns = 0
    latest = ""
    while True:
        c = [0.0] * n
        for v in s[:-1]:
            for i, x in enumerate(v[0]):
                c[i] += x / n
        data = '{} {} {}'.format(count, s, latest)
        if s[0][1] < best:
            stuck_count = 0
            best = s[0][1]
        else:
            stuck_count += 1
        if stuck_count > stuck_limit:
            raise RuntimeError("STUCK for {} steps! ".format(stuck_count) + data)
        if count > limit:
            raise RuntimeError("ABANDONED after {} steps! ".format(count) + data)
        if max([abs(s[0][0][i] - c[i]) for i in dim]) < ε and abs(s[0][1] - s[-1][1]) < ε:
            return s[0], count, nr, ne, nc, ns
        count += 1
        xr = [c[i] + α * (c[i] - s[-1][0][i]) for i in dim]
        fr = f(xr)
        if s[0][1] <= fr < s[-2][1]:
            nr += 1
            del s[-1]
            s.append([xr, fr])
            continue
        if fr < s[0][1]:
            xe = [c[i] + γ * (c[i] - s[-1][0][i]) for i in dim]
            fe = f(xe)
            ne += 1
            del s[-1]
            s.append([xe, fe] if fe < fr else [xr, fr])
            latest = "expansion" + ("(e)" if fe < fr else "(r)")
            continue
        xc = [c[i] + ρ * (c[i] - s[-1][0][i]) for i in dim]
        fc = f(xc)
        if fc < s[-1][1]:
            nc += 1
            del s[-1]
            s.append([xc, fc])
            continue
        reduced = [s[0]]
        for v in s[1:]:
            xs = [s[0][0][i] + σ * (v[0][i] - s[0][0][i]) for i in dim]
            reduced.append([xs, f(xs)])
        ns += 1
        s = reduced
Here is the test code, now including a simple constrained optimization at the end:
Python:
from sys import argv, float_info
        self.a = a
        self.b = b
    def func(self, z):
        x, y = z
def himmelblau(z):
    x, y = z
def basic(z):
    x, y = z
    f = x**2 + y**2 - 4.0
    c = 0.0 if x + y >= 2.0 else float_info.max
    return f + c
    # Example: python Rosenbrock.py 3.0 3.0 0.1 0.1
    print(nelder_mead(Rosenbrock(1.0, 100.0).func, init, deltas, 1.0e-9))
    print(nelder_mead(himmelblau, init, deltas, 1.0e-9))
    print(nelder_mead(basic, init, deltas, 1.0e-9))
