What is the Notation for Adjoints in Matrices?
  • Level: Graduate
  • Thread starter Thread starter ac_nex
    Determinants
14 replies · 7K views · last reply
ac_nex
Just wondering, how would you solve a problem such as this one:
Suppose A is an 5 x 5 matrix, with det(A) = 2 find the following:
det(A^-1 + adj(A))
Thanks in advance.
my first instinct is to multiply by A to see what happens, but I don't know the definition of adj(A). so I don't know what adj(A).A is.then use the fact that det respects products.
if adj means the adjugate, that is the transpose of the matrix of minors (which I guess some people also call the adjoint, but I save that for the Hermitian adjoint), then use the fact that A^-1=adj(A)/det(A)
A*A^-1 = I
det(A*A^-1)=det(I)=5
det(A)*det(A^-1)=5
2*det(A^-1)=5
det(A^-1)=5/2
A*Adj(A) = det(A)*I
det(Adj(A)) = det(A)^(n-1)
det(adj(A)) = 2^4 = 16
I'm pretty sure that det(1)=1
:redface:
of course!
A^-1 = adj(A)/det(A)
=> adj(A)= det(A)*A^-1
det(A)=2 given
adj(A) = 2A^-1
A^-1 + adj(A) = A^-1 + 2 A^-1
=3 A^-1
det (3A^-1) = 3 det(A^-1) = 3 (det(A))^-1
=3*2^-1
=3/2
How's This
Tough question!
Actually guys, thanks for considering my question, but I am afraid all of your answers are different from what the actual answer is.
It says the answer is (3^5)/2
Any usefull remarks.
Sorry in my earlier solution there was a problem
This is the correct solution
det(A)=2 given
adj(A) = 2A^-1
=3 A^-1
=>det (3A^-1)
since A is 5*5 matrix
det(3A^-1)=3^5 det(A^-1)
=3^5 (det A)^-1
=3^5 (2)^-1
=3^5/2
enjoy
neo143 says that det (3A^-1) = 3 det(A^-1), which is incorrect. You should be able to fix this easily yourself, though.
A^-1 = (1/2)*adj(A)
A^-1 + adj(A) = (1/2)*adj(A) + adj(A) = (3/2)*adj(A)
det(a*A) = (a^n)*det(A)
so, det(3/2*adj(A)) = (3/2)^5 * det(adj(A))
A^-1 = adj(A)/det(A) , adj(A)=(1/2)*(A^-1) , A*A^-1 = I , det(A*A^-1)=1=det(A)*det(A^-1) , det(A^-1) = 1/2
A^-1 = (1/2)*adj(A)
adj(A) = 2*(A^-1)
det(adj(A)) = (2^5)*(1/2)
det(3/2*adj(A)) = ( (3/2)^5 ) * (( 2^5))/2 = 121.5
Edit: you already got it
Thanks, I already knew how to do it after some serious thinking about neo143's first post. Thanks again.
i think i completely solved it for you, modulo the definition of adj.
i.e. since adj(A).det(A) = A^(-1),
my advice gives det(A)det(A^(-1)+adj(A)) = det(I + 2I) = det(3I) = 3^5.
hence det(A^(-1)+adj(A)) = 3^5/2.
how many definitions does adjoint take?
1) there is the classical adjoint (its exact definition too messy to write) which has the useful relation A^(-1)=Adj(A)/det(A).
2) then there is the definition of adjoint as the transpose and conjugate of a matrix.
These two adjoint operation are different. May i know what notation is usually used? Adj?
