What is the Notation for Adjoints in Matrices?
  • Context: Graduate
  • Thread starter Thread starter ac_nex
    Determinants
14 replies · 7K views
ac_nex
Just wondering, how would you solve a problem such as this one:
Suppose A is an 5 x 5 matrix, with det(A) = 2 find the following:
det(A^-1 + adj(A))
Thanks in advance.
my first instinct is to multiply by A to see what happens, but I don't know the definition of adj(A). so I don't know what adj(A).A is.then use the fact that det respects products.
isn't adj(A) the adjoint matrix?
if adj means the adjugate, that is the transpose of the matrix of minors (which I guess some people also call the adjoint, but I save that for the Hermitian adjoint), then use the fact that A^-1=adj(A)/det(A)
A*A^-1 = I
det(A*A^-1)=det(I)=5
det(A)*det(A^-1)=5
2*det(A^-1)=5
det(A^-1)=5/2
A*Adj(A) = det(A)*I
det(Adj(A)) = det(A)^(n-1)
det(adj(A)) = 2^4 = 16
I'm pretty sure that det(1)=1
:redface:
of course!
A^-1 = adj(A)/det(A)
=> adj(A)= det(A)*A^-1
det(A)=2 given
adj(A) = 2A^-1
A^-1 + adj(A) = A^-1 + 2 A^-1
=3 A^-1
det (3A^-1) = 3 det(A^-1) = 3 (det(A))^-1
=3*2^-1
=3/2
How's This
Tough question!
Actually guys, thanks for considering my question, but I am afraid all of your answers are different from what the actual answer is.
It says the answer is (3^5)/2
Any usefull remarks.
Sorry in my earlier solution there was a problem
This is the correct solution
det(A)=2 given
adj(A) = 2A^-1
=3 A^-1
=>det (3A^-1)
since A is 5*5 matrix
det(3A^-1)=3^5 det(A^-1)
=3^5 (det A)^-1
=3^5 (2)^-1
=3^5/2
enjoy
neo143 says that det (3A^-1) = 3 det(A^-1), which is incorrect. You should be able to fix this easily yourself, though.
A^-1 = (1/2)*adj(A)
A^-1 + adj(A) = (1/2)*adj(A) + adj(A) = (3/2)*adj(A)
det(a*A) = (a^n)*det(A)
so, det(3/2*adj(A)) = (3/2)^5 * det(adj(A))
A^-1 = adj(A)/det(A) , adj(A)=(1/2)*(A^-1) , A*A^-1 = I , det(A*A^-1)=1=det(A)*det(A^-1) , det(A^-1) = 1/2
A^-1 = (1/2)*adj(A)
adj(A) = 2*(A^-1)
det(adj(A)) = (2^5)*(1/2)
det(3/2*adj(A)) = ( (3/2)^5 ) * (( 2^5))/2 = 121.5
Edit: you already got it
Thanks, I already knew how to do it after some serious thinking about neo143's first post. Thanks again.
i think i completely solved it for you, modulo the definition of adj.
i.e. since adj(A).det(A) = A^(-1),
my advice gives det(A)det(A^(-1)+adj(A)) = det(I + 2I) = det(3I) = 3^5.
hence det(A^(-1)+adj(A)) = 3^5/2.
how many definitions does adjoint take?
1) there is the classical adjoint (its exact definition too messy to write) which has the useful relation A^(-1)=Adj(A)/det(A).
2) then there is the definition of adjoint as the transpose and conjugate of a matrix.
These two adjoint operation are different. May i know what notation is usually used? Adj?
