What is the Perturbation in the Modified Coulomb Model of a Hydrogen Atom?
The discussion revolves around the modified Coulomb model of a hydrogen atom, specifically addressing a deviation from Coulomb's law at very small distances. The problem involves calculating the perturbation and its effects on the ground-state energy of the hydrogen atom.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the perturbation defined for the modified Coulomb model and its implications for the ground-state energy correction. There are attempts to derive the first-order energy correction and questions about the validity of certain simplifications made during calculations.
Some participants have shared their calculations and results, while others have expressed confusion regarding specific steps and interpretations of the problem. There is an ongoing exploration of how to deduce the largest value of the parameter ##b## in relation to the agreement of the modified model with the Coulomb model.
Participants are considering the requirement that the ground-state energy of the hydrogen atom must agree with the predictions of the Coulomb model to one part in a thousand, which introduces a constraint on the value of ##b##.
Leechie
Suppose there is a deviation from Coulomb's law at very small distances, with the mutual Coulomb potential energy between an electron and a proton being given by:
$$V_{mod}(r)= \begin{cases} - \frac {e^2} {4 \pi \varepsilon_0} \frac {b} {r^2} & \text {for } 0 \lt r \leq b \\ - \frac {e^2} {4 \pi \varepsilon_0} \frac {1} {r} & \text {for } r \gt b \end{cases}$$
where ##e## is the magnitude of the electon charge, ##\varepsilon_0## is the permittivity of free space, ##r## is the electron-proton separation and ##b## is a constant length that is small compared to the Bohr radius but large compared to the radius of a proton. Throughout this question, the perturbed systen, with ##V(r)## replaced by ##V_{mod}(r)##, will be called the modified Coulomb model.
a) Specify the perturbation for the modified Coulomb model of a hydrogen atom relative to the unperturbed Coulomb model.
b) Use this perturbation to calculate the first-order correction, ##E_1^{(1)}## to the fround-state energy of a hydrogen atom in the modified Coulomb model, givesn that the fround-state energy eigenfunction for the unperturbed Coulomb model is:
$$\psi_{1,0,0} \left( r,\theta,\phi \right) = \left( \frac {1} {\pi a_0^3} \right)^{1/2} e^{-r/a_0} $$
c) Show that your answer to part (b) can be approximated by
$$E_1^{(1)} \approx - \frac {4b^2} {a_0^2} E_R$$ where ##E_R = {e^2} / 8 \pi \varepsilon_0 a_0## is the Rydberg energy. Hence deduce the largest value of ##b## that would be consistent with the fact that the ground-state energy of a hydrogen atom agrees with the predictions of the Coulomb model to one part in a thousand. Express your answer as a numerical multiple of ##a_o##.
$$\int_0^x e^{-u} du = 1-e^{-x}$$ $$\int_0^x u e^{-u} du = 1-e^{-x}-xe^{-x}$$ for ##x \ll 1##,$$e{-x}=1-x+ \frac {x^2} {2} $$
a)
##\delta \hat {\mathbf H}= - \frac {e^2} {4 \pi \varepsilon_0} \left( \frac {b} {r^2} - \frac 1 r \right)##
b)
##E_1^{(1)}= - \frac {e^2} {\pi \varepsilon_0 a_0^3} \left( \frac {a_0b} {2} \left(1-e^{-2b/a_0} \right) - \frac {a_0^2} {4} \left(1-e^{-2b/a_0}-\frac {2b} {a_0} e^{-2b/a_0} \right) \right) ##
c)
This is where I'm having problems. I can get ##E_1^{(1)} \approx - \frac {4b^2} {a_0^2} E_R## by setting ##e^{-2b/a_0}=1## since ##b \ll a_0## and then integrate in the same way I did to get to answer (b), but should I be using my answer to part (b) to show ##E_1^{(1)} \approx - \frac {4b^2} {a_0^2} E_R## because I can't make it do that.
Also, I'm not sure how to proceed from here to deduce the largest value of ##b##, and I'm a bit unclear to what the question means by "agrees with the predictions of the Coulomb model to one part in a thousand".
Can anyone offer and advice with this please.
I got a different result for (b). Can you show us your calculations?
This is how I got to (b):
$$\begin{align} E_1^{(1)} & = \int_0^\infty R_{nl}^*(r) \delta \hat {\mathbf H} R_{nl}(r) r^2 dr \nonumber \\ & = \int_0^b \left( \frac {1} {a_0} \right)^{3/2} 2e^{-r/a_0} \left( - \frac {e^2} {4 \pi \varepsilon_0} \right) \left( \frac {b} {r^2} - \frac 1 r \right) \left( \frac {1} {a_0} \right)^{3/2} 2e^{-r/a_0} r^2 dr \nonumber \\ & = \int_0^b \left( - \frac {e^2} {4 \pi \varepsilon_0} \right) \left( \frac {b} {r^2} - \frac 1 r \right) \frac {4} {a_0^3} e^{-2r/a_0} r^2 dr \nonumber \\ & = - \frac {e^2} {\pi \varepsilon_0 a_0^3} \int_0^b \left( \frac {b} {r^2} - \frac 1 r \right) e^{-2r/a_0} r^2 dr \nonumber \\ & = - \frac {e^2} {\pi \varepsilon_0 a_0^3} \int_0^b \left( b - r \right) e^{-2r/a_0} dr \nonumber \\ & = - \frac {e^2} {\pi \varepsilon_0 a_0^3} \left( \int_0^b b e^{-2r/a_0} dr - \int_0^b r e^{-2r/a_0} dr \right) \nonumber \end{align} $$
Then I used the given integrals to get to:
$$\int_0^b b e^{-2r/a_0} dr = \frac {a_0 b} {2} \int_0^{2b/a_0} e^{-u} du = \frac {a_0 b} {2} \left( 1 - e^{-2b/a_0} \right) $$
And
$$\int_0^b r e^{-2r/a_0} dr = \frac {a_0^2} {4} \int_0^{2b/a_0} u e^{-u} du = \frac {a_0^2} {4} \left( 1 - e^{-2b/a_0} - \frac {2b} {a_0}e^{-2b/a_0} \right) $$
Then I substituted back into get my answer for (b). Have I messed this up somewhere?
Oops, my mistake, I simplified your answer incorrectly. You have some terms that will cancel out, and you should end up with
$$\frac{k e^2}{a}\left(1-\frac{2b}{a} - e^{-2b/a}\right),$$ where ##k = \frac{1}{4\pi\varepsilon_0}##. Now expand the exponential term to second order, and you'll get the result you seek.
Thanks vela. I see how that all fits together now.
I'm still a little confused with this bit though:
I know how to find the largest value of ##b## using a derivative (if that's what the questions is asking), but I'm not sure I understand the bit about 'one part in a thousand'. I'm thinking the idea behind this is to find the point where the Coulomb model first matches the ground state as ##b## increases from ##0##, which would be the maximum value ##b##?
The question is asking when do the unperturbed and perturbed energies differ by less than 0.1%.
I think I know where I'm heading now, thanks.
