What is the ph of .035M acetic acid ?
  • Thread starter Thread starter vikki99
    Acid Ph
The discussion revolves around calculating the pH of a 0.035M acetic acid solution and includes related queries about the pH of a sodium hydroxide solution. Participants explore the dissociation of acetic acid and methods for solving the associated equations.
  • Homework-related
  • One participant requests insight into calculating the pH of 0.035M acetic acid and 0.01M NaOH.
  • Another participant explains that NaOH fully dissociates, leading to a straightforward calculation of pH, while acetic acid does not fully dissociate, requiring the dissociation constant for calculations.
  • The dissociation constant for acetic acid is mentioned as 1.8 x 10-5 mol2L-2, and a method for calculating pH using this value is outlined.
  • Participants discuss the quadratic equation involved in calculating the pH of acetic acid, with one suggesting that omitting x simplifies the calculation.
  • Another participant inquires about solving the quadratic equation for a more general case of acid concentration and mentions a method of successive approximations to avoid solving the quadratic directly.
  • A participant emphasizes the importance of showing the mathematical process rather than just providing answers, suggesting a focus on understanding the equilibrium constant.
Participants express differing views on the approach to calculating pH, particularly regarding the treatment of the dissociation of acetic acid and the use of approximations. No consensus is reached on the best method to solve the problem.
Limitations include the dependence on the accuracy of the dissociation constant provided and the assumptions made when omitting x in calculations. The discussion does not resolve the complexities involved in the quadratic equation for varying concentrations.
vikki99
can someone give me some insight to solve this
in detail :
what is the ph of .01 Naoh ?
and what is the ph of .035M acetic acid ?
Chemistry news on Phys.org
Hello,
The first question can easily be solved, since NaOH fully dissociates. But I can not say the same for acetic acid, you'll need to give the dissociation constant for it. I remember that it is 1,8*10^{-5} mol^2L^{-2}, and will solve by using this value. If I'm mistaken, please replace it with the correct one.
Firstly, let's look at NaOH:
\underbrace{NaOH} \rightarrow \underbrace{Na^+} + \underbrace{OH^-}
\overbrace{0,01-x} \rightarrow \overbrace{x} + \overbrace{x}
Since dissociation constant for NaOH is extremely big, we never need to calculate the {0,01-x}; it has a very very close value to 0,01. So we can easily assume that the [OH^-] is 0,01, the same goes for [Na^+].
As pH is the negative logarithm of [H^+] or \frac{10^{-14}}{[OH^-]}, we'll use whichever is suitable. Since we know the hydroxide concentration, let's use this:
pH=-\log(\frac{10^{-14}}{0,01})=12.
For acetic acid, we'll consider the x values as it is not dissociated 100% in water.
\underbrace{CH_3COOH} \rightarrow {CH_3COO^-}+{H^+}
\overbrace{(0,035-x)}\rightarrow
We are given that \frac{x^2}{(0,035-x)}=1,8*10^{-5}. Then it's easy to find x, either by omitting it or by solving a two-unknown equation with \Delta=b^2-4ac and x_1=\frac{-b-\sqrt{\Delta}}{2a} and x_2=\frac{-b+\sqrt{\Delta}}{2a}. Note that only one root gives a valid value, just omit the other.
I will not consider x, if you really wonder, you may not omit it and solve the two-unknown equation. When we omit it, we'll find that x=\sqrt{0,035*1,8*10^{-5}}=7,94*10^{-4}, hence we find the pH to be 3,1.
Regards,
chem_tr
thank chem_tr I have one more question :
Solve the quadratic equation for the more general case where the total concentration of acid is:
a. ((Ao = (HA) + (A-) ) has any value Ao.
b. One can avoid solution of the quadratic equation by using a method of successive approximations, starting with x2 =AoKa.
Explain how this would be done.
thanks again for the help earlier
Hello,
I will not be as "helpful" as I did before, since it may not help you as I intended; I don't want to be harmful for your education. I decided to show you the way instead, that's better for you I think.
The total is the initial concentration of the acid. So you disregard how much of it is ionized; just give the initial concentration, and it is over. It is your task to show it mathematically.
If H+ and A- are said to be ionized as much as x, then you may easily write the equilibrium constant using C0, Ka, and x2, along with my earlier posts of course :smile:
Best wishes and have a good study,
chem_tr
THANK YOU CHEM_tr
thanks soooooooooooooooooooooooo much for your help
you are not ruining my education
I don't have a lot of support here at the school I am attending at the only tutor is a bit "special " i mean slow.
thanks again
