What Is the Physics Behind Particle Traveling Over Voltage?
  • Context: Undergrad
  • Thread starter Thread starter TBert
    E&m Quantum
The discussion revolves around the physics of charged particles traveling over a voltage, particularly focusing on the concepts of potential barriers and quantum mechanics. Participants explore the implications of energy levels, potential barriers, and the interpretation of a diagram related to these phenomena.
  • One participant describes a diagram that illustrates the probability of finding a charged particle when traveling over a voltage, questioning the underlying physics.
  • Another participant suggests looking up quantum tunneling, but notes that the scenario described differs from traditional quantum tunneling due to the absence of a barrier.
  • A participant asserts that the situation involves a potential barrier, stating that if the particle has enough energy, it can "jump" the barrier, referencing quantum mechanics principles.
  • There is a challenge to the idea of a potential barrier, with a participant arguing that the description provided by their friend indicates it is not a barrier or related to quantum tunneling, but rather a force associated with electricity.
  • One participant mentions Schrödinger's equation in relation to the discussion, suggesting that the diagram may not correspond to a correct solution of that equation.
  • Concerns are raised about the clarity of the diagram, specifically regarding the axes and what they represent, with some participants questioning the terminology used, such as "amount of particle."
Participants express differing views on whether the scenario involves a potential barrier or not, with some asserting it does and others contesting this interpretation. The discussion remains unresolved regarding the correct interpretation of the diagram and the physics involved.
There are limitations in understanding due to unclear definitions and the representation of the diagram, which may not accurately convey the intended physics. The discussion also highlights the complexity of interpreting quantum mechanics concepts in this context.
TBert
A friend of mine showed me a diagram like this:
I think they said it was describing the probability of finding a charged particle in a certain place when traveling over a voltage. They said that if the particle doesn't have enough energy to make it across then it gets stuck at the beginning of the voltage. I'm wondering if anyone can identify what effect/physics law this is a give me a better description of how it works
Look up quantum tunneling.
Thanks
Bill
Thanks
Bill
They said it was different from quantum tunneling though because there wasn't a barrier the was being passed
Its a potential barrier. If it has enough energy it can jump the barrier. That's the funny thing about QM because it doesn't have an energy until actually measured it can be found outside a barrier that doesn't require an infinite energy to jump.
The QM particle in a box might be slightly more instructive for you. Have a look at the infinite barrier box first then the case of a finite wall:
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/pbox.html
Thanks
Bill
Thanks
Bill
Are you sure it is a potential barrier? They seemed very sure about the fact that it wasn't a barrier or quantum tunneling. They made it seem like it was a force to the electricity.
That's what a potential barrier is.
People use the word "tunnelling" more or less narrowly to describe the phenomena that are observed when an incident wave encounters a change in potential, but the physics you're looking for is Schrödinger's equation for a one-dimensional potential... But I don't think your diagram corresponds to any correct solution of that equation.
Did he tell you what the horizontal and vertical axes of the diagram represent? If not, it's really hard to know what the diagram is supposed to be telling you.
Looks like someone took a sloppy representation of the first excited state of a particle in a well and elevated it above the well. I certainly wouldn't put any stock in this image.
For the curvy line on top the vertical axes is the amount of particle in the position and the horizontal axes is the position (like in one dimension). For the bottom line the vertical and horizontal axes show where the charge is.
What does this mean? "Amount of particle" is not a physical quantity.
Are you sure?
  • · Replies 0 ·
  • · Replies 36 ·
9K
  • · Replies 46 ·
  • · Replies 86 ·
13K
  • · Replies 17 ·
  • · Replies 43 ·
  • · Replies 0 ·
