What is the potential energy of the spring?
The potential energy of a spring can be calculated using the formula U = 1/2 kx², where k is the spring constant and x is the displacement from the equilibrium position. In this discussion, the displacement x was determined to be 0.2 meters using the equation x = A cos(wt), with an amplitude A of 0.33 meters and angular frequency ω of 20.1. The relationship between angular frequency and the spring constant is established by the equation ω² = k/m, which allows for the calculation of k if the mass and ω are known.
  • Understanding of harmonic motion and spring mechanics
  • Familiarity with the equations of motion, specifically x = A cos(wt)
  • Knowledge of angular frequency and its relationship to spring constant
  • Basic algebra for solving equations involving k and x
  • Calculate the spring constant k using the relationship ω² = k/m
  • Explore the implications of varying amplitude on potential energy
  • Learn about energy conservation in harmonic oscillators
  • Investigate the effects of mass on the oscillation frequency of springs
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for practical examples of potential energy in springs.
zachmgilbert
mass=.52 kg
velocity=-6.54sin(20.1t)
time=40.84 seconds
amplitude=.33 meters
angular frequency=20.1
U =1/2kx2
I used x=Acos(wt) and got .2 meters for x. I know this is right.I don't know how to find k.
x=Acos(wt)
This solution only satisfies the differential equation m\ddot{x}=-kx if \omega^2 = k/m
What is \omega^2?
angular frequency squared
OK.
If I may ask, what is the independent variable in x=Acos(wt)? I'd like to solve it...
Char. Limit said:
OK.
Hello Char!
The independent variable is time(t) right? The position(x) depends on it.
You now have x,t & k, you should be able to solve for U.
Ah, I have the an-word (answer comes from an-swear, meaning "an-word")
I actually wanted to prove the diff e.q. That was mentioned, but I got carried away. The answer is..
Aaaaaaaauuuggh...
Hello Winzer!
Then how come the amplitude is 0.33 m?
Anyhow, if you're absolutely sure it's 0.2 m and not 0.33 m, w^2=k/m.
  • · Replies 17 ·
  • · Replies 28 ·
