What Is the Potential of a Charge Above an Infinite Conducting Slab?
The discussion revolves around finding the electric potential due to a point charge placed above an infinite conducting slab, specifically at the coordinates (0,0,d) where the slab is located at z<=0. The original poster seeks to solve this problem without employing the image-charge method, utilizing Laplace's equation and its solutions in spherical coordinates.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to express the potential as a superposition of contributions from the slab and the point charge, leading to a series expansion involving Legendre polynomials. They question how to determine the coefficients for odd terms in the series after establishing boundary conditions.
  • Some participants raise concerns about the boundary conditions related to the electric field at the conducting slab, particularly regarding the radial component of the electric field.
  • Others suggest reconsidering the orientation of the angles used in spherical coordinates and the implications for the electric field components at the slab's surface.
  • There is a mention of integrating the electric field due to the surface charge distribution on the conductor and how it relates to the point charge's field.
The discussion is ongoing, with participants exploring various interpretations of boundary conditions and the implications for the coefficients in the potential series. Some guidance has been offered regarding the normal component of the electric field at the conductor's surface, but no consensus has been reached on the overall approach or solution.
Participants note the complexity of the problem due to the need to satisfy multiple boundary conditions and the challenge of determining the induced surface charge distribution on the conducting slab. There is also an acknowledgment of the limitations imposed by the requirement to avoid the image-charge method.
danielakkerma
Hello everyone!
A charge, +q, is placed above an infinite conducting slab located at z<=0, at (0,0,d). Find the potential everywhere in space, without using the image-charge method.
Laplace's equation(and its solution in spherical coordinates).
(CGS units used throughout)
Firstly, I considered that according to Laplace's equation, the potential in space should a superposition of the potential emanating from the slab, with the one generated by the point-charge. So I get:
[tex] V = V_c + V_q[/tex]
Where:
[tex]V_c = \sum_{n=0}^{\infty} (A_n r^n + \frac{B_n}{r^{n+1}}) P_n(\cos(\theta)) \\ <br /> V_q = \frac{q}{\sqrt{r^2+d^2 -2 r d \cos(\theta)}}[/tex]
Where Pn is the ordinary Legendre polynomial of Nth order.
Then, I expanded Vq into a series form(using Legendre's development), and separating Vc according to basic boundary conditions(V = 0, at infinity. V<∞, as r→0). I get:
[tex] V(r, \theta) = \left\lbrace <br /> \begin{align}<br /> \frac{q}{d}\sum \left( \left(\frac{r}{d}\right)^n + \frac{d}{q} A_n r^n \right) P_n(\cos(\theta)), && r < d \\<br /> \frac{q}{r}\sum \left( \left(\frac{d}{r}\right)^n + \frac{1}{q} \frac{B_n}{r^n} \right) P_n(\cos(\theta)), && r>d<br /> \end{align}<br /> \right.[/tex]
Now I apply the most important boundary cond. on the potential: at its surface, i.e. when z = 0, or, in other words, when θ=π/2, I should get an equipotential. Here, I've calibrated it, to be simply zero. I then get the following two equations(one for each of the separate values of the potential: r<d & r>d):
[tex] \frac{q}{d}\sum \left( \left(\frac{r}{d}\right)^n + \frac{d}{q} A_n r^n \right) P_n(0) = 0 \\<br /> \frac{q}{r}\sum \left( \left(\frac{d}{r}\right)^n + \frac{1}{q} \frac{B_n}{r^n} \right) P_n(0) = 0[/tex]
Now, for all n=2k+1 the terms in the sum vanish instantly(and hold for any coefficient therein), since P2k+1(0) = 0, by the anti-symmetry of odd Legendre polys.
The values of the even coefficients can then easily be determined.
But that still leaves the question of the odd ones, open.
How do I obtain them?
No reasonable guess as to their value can get me close to the expected value -- which is what one would obtain through image charges.
As always,
Would appreciate any advice or aid,
Thanks for your help,
Daniel
There is another boundary condition, having to do with the conducting of the slab: the E field lines at the slab cannot have a radial component!
Thanks for your response..
Thanks for your reply.
Unfortunately, taking the gradient of E, and projecting onto the radial direction, at θ=Pi/2 creates a problem.
It does, as you rightly point out, equal Etangential, and that in turn should be zero; however, when taking it, I obtain again(for instance, when r < d):
[tex] n \left (q \left (\frac{r}{d}\right )^{n-1} + A_n r^{n-1} \right ) P_n(0) = 0[/tex]
Which leads unfortunately to an erroneous result:
That is, once again, realizing that only even components do not identically vanish, I arrive at:
[tex] \left (q \left (\frac{r}{d}\right )^{(2n-1)} + A_{2n} r^{(2n)-1} \right )=0 \Rightarrow A_{2n} = -\frac{q}{d^{2n-1}}[/tex]
However, I obtain here the exact same result as from the potential. Hence, it's not getting me anywhere.
Hence, I am still stumped.
Whereto forward?
Thanks,
Daniel
I hate to bump this,
But does anyone have any ideas as to how to proceed?
The slab plane has ##\theta = 0##, not ##\pi/2##
I don't quite follow
Sorry,
I don't quite get that.
The plane (x-y) which is located where z=0 is attained when θ = π/2, since, in the the (standard) spherical system: [itex]r_z = r \cos(\theta)[/itex].
If I were to apply θ=0 on E, I would obtain the field perpendicular to the surface, which, according to Gauss' law should give the surface charge dist., but (that) which is unknown to me.
If you could therefore explain what exactly you meant by θ=0, that would be much appreciated.
Thanks again!
Daniel
Yep, sorry, my mistake. Not good at all.
Have to re-think this one...does V = 0 at ##\cos\theta = 0 ## imply that ##\vec E## only has a ##\theta## component there...
At θ=0 the vector would be along the z-axis, aligned with the external point-charge. V is not zero there.
If I plug in θ=Pi/2, I would indeed see that theta is perpendicular to the surface. Still, since I don't know the induced surface charge dist., I doesn't advance me anywhere.
[Thought I posted this yesterday-don't find it back]
Looked around a bit, came up with next to nothing. Quoting http://ecee.colorado.edu/~ecen3400/Chapter%206%20-%20Conductors%20in%20the%20Electrostatic%20Field.pdf on subject of point charge above a large, grounded conducting sheet: "Although it's possible to determine this distribution starting from an integral equation, ..." and goes on with image charge.
At ##\theta = \pi/2## (ahem..:redface:) the radial component of field from surface charge has to cancel same from point charge at z = d. Should be feasible to work this out.
Were the spherical coordinates and the spherical harmonics in the formulation of the exercise, or did you bring them in yourself ?
Thank you for replying.
It was in fact my idea to develop a series formulation of the potential [itex]\frac{1}{|\vec{r}-\vec{r}'|}[/itex] with Legendre's polynomials, as that would give me an orthonormal basis, which in turn should have made finding the coefficients easier. Plus, it seemed like the natural thing to do, given that the solution to Laplace's equation from the conductor could also be written through Legendre's expansion. So that was the reasoning behind that.
At θ=π/2 (ahem..) the radial component of field from surface charge has to cancel...
Viz. your previous suggestion as well, I had already derived the radial field, at θ = Pi/2, which I wrote here(Once again, only even coefficient do not vanish identically):
Plugging in r=d, still gives me the same value of A2n. So that's unfortunately not leading anywhere. :frown:
I think however that the problem may be reoriented: knowing the solution in advance permits me to establish what coefficients I would need for the series to converge to the desired function; As I've said, it must be an alternating series of the form [itex]A_n \propto (-1)^{n}[/itex].
So perhaps that's what we should be focusing on; namely, a boundary condition that could generate such a term. That's where I am still stuck.
Thanks again!
Once again, apologize for bumping...
Does anyone have any leads?
Same thing again -- built a post, doesn't show up. Must have not submitted the thing. Anyway:
Radial component of E field from q at the conductor location is $$E = {1\over 4\pi\epsilon_0}{q\over r^2 + d^2}{r\over \sqrt{ r^2 + d^2}}\quad\quad {\rm (a)}$$
Has to be compensated by opposite and equal component due to surface charge distribution on conductor. Can assume circular symmetry so ##\sigma(\vec r) = \sigma(r)## in x,y plane. Radial component is $$E={1\over 4\pi\epsilon_0} \int_0^r\int_0^{2\pi} {\sigma(r') \over (r- r' \cos\phi)^2 + (r'sin\phi)^2}{r'\sin\phi \, d\phi\, dr' \over \sqrt{(r- r' \cos\phi)^2 + (r'sin\phi)^2}}$$
Setting the outcome of this integral equal to -(a) is the integral equation Popovic mentions. Then still have to work out the expression for E in all space. A lot of work, so I'm open to suggestions to do it more efficiently.
Errede 6 has a lot of useful info.
Hello, danielakkerma.
It took me quite a while to see how to add another condition that will allow you to get the even-n coefficients. Finally thought of something that appears to work.
See if you can argue that at the surface of the conducting plane, the normal component of E from Vq must equal the normal component of E from Vc. The normal component of E at the conductor is Eθ = -(1/r)∂V/∂θ evaluated at θ = π/2.
This introduces a derivative of each Pn(cosθ) with respect to θ in the series expansions. I found the following identity to be useful:
(1-x2)P'n(x) = nPn-1(x)-nxPn(x) ##\;\;\;## (e.g., Jackson's text page 90)
Here, x = cosθ and the identity simplifies nicely for x = 0 (corresponding to θ = π/2).
Sorry, I meant to say "odd-n coefficients".
Danny isn't happy yet, I take it ?
Thank you both!
Thanks so much for your efforts, BvU & TSny! Sorry it has taken me a while to reply!
I looked over your suggestions, BvU, and I fear that such an integral equation would be impossible to solve, without a priori working out σ -- i.e. the surface charge distribution. Furthermore, it is typically necessarily to solve for the potentials(as far as I see it) in order to actually obtain the former(σ). Hence, unless you could delve more into the subject, I don't see how one might advance with that, as is.
TSny, it too occurred to me that one ought to consider the electric field in the θ direction, as you suggest.
However, so far, I haven't found a compelling reason to justify it -- even though, as you rightly point out, it will produce the correct result.
The strongest possible rationalization of your method would be to consider the flux through an element of the surface; However, since the charge on the conductor through some small parcel dS would necessarily be smaller than the net flux from the field of the charge through the same surface(since σ on the conductor is not uniform), I don't see how one can quantify it, through that.
If you have an other ideas on how to substantiate it, I would appreciate, as always, any offers thereunto.
But I think we're now closer than ever!
Thanks again, to both of you, for your amazing help!
Daniel
There will be a nonuniform, induced negative surface charge density on the surface of the conducting slab. At a point just outside or inside the conductor, there will be an electric field produced by all of the surface charge. This electric field will have both normal and radial components.
Because the surface is a flat plane, the field produced by the surface charge must be "mirror symmetric" with respect to the plane as shown in the left figure of the attachment. Thus the normal component just inside the conductor will be equal in magnitude but opposite in direction of the normal component just outside.
Now add in the normal component of the field due to the point charge as shown in the right figure. The normal component of this field is continuous as you pass through the surface of the conductor.
We know that the total field inside the conductor must be zero. So, that tells us something about the magnitudes of the normal components of the two fields inside the conductor. Then we can make a conclusion about the magnitudes of the normal components just outside the conductor.
TSny,
Thank you very much! I finally have my head around the solution. You're absolutely right(as I see it, now) that the view of fields nearest to the conductor can be considered through their analogues within the slab. And furthermore, the normal components are related through the need to have the electric field identically zero within.
Once again, it's a very cogent elucidation! (and I am especially beholden for the useful illustrations you provided).
As an aside, I had calculated the radial components at θ = 0 (which would merely reproduce the normal direction) -- reached the same coefficients, and thus, made sure that the definitions thereof are consistent(as one would expect).
So, once more,
Many thanks for your help, TSny & BvU,
Daniel
  • · Replies 19 ·
  • · Replies 16 ·
