What is the Proof of an Inequality for Three Positive Numbers?
  • Context: Undergrad
  • Thread starter Thread starter tomwilliam2
    Inequality Proof
The inequality \((a+b)(b+c)(c+a) \geq 8abc\) for non-negative numbers \(a, b, c\) can be proven using the Arithmetic Mean-Geometric Mean (AM-GM) inequality. Key steps include proving that \(a + b \geq 2\sqrt{ab}\) and applying AM-GM to the expression \(2abc + a^2b + ac^2 + b^2c + b^2a + bc^2 + a^2c\). Additionally, the approach involves considering cases where one or more variables are zero and leveraging the positivity of the variables to simplify the expression.
  • Understanding of the Arithmetic Mean-Geometric Mean (AM-GM) inequality
  • Familiarity with algebraic expansion and rearrangement
  • Basic knowledge of inequalities involving positive real numbers
  • Experience with mathematical proofs, particularly in inequality contexts
  • Study the application of the AM-GM inequality in various mathematical contexts
  • Explore proofs of similar inequalities involving multiple variables
  • Learn about induction techniques for proving inequalities
  • Investigate the properties of symmetric sums and their applications in inequalities
Mathematicians, students preparing for competitions like the Putnam Exam, and anyone interested in advanced algebraic inequalities will benefit from this discussion.
tomwilliam2
I'm trying to do some practice Putnam questions, and I'm stuck on the following:
For ##a,b,c \geq 0##, prove that ##(a+b)(b+c)(c+a) \geq 8abc##
(https://www.math.nyu.edu/~bellova/putnam/putnam09_6.pdf)
I started off by expanding the brackets and doing some algebraic rearranging, but I don't think I've got anywhere.
Should I be using induction? Or is this an algebraic problem?
Thanks in advance
Mathematics news on Phys.org
My hint is to first prove
##a + b \geq 2\sqrt {ab}##. You can start by using ##(a - b)^2 \geq 0##. If you prove it then see how you can leverage this for the whole expression you want to prove.
EDIT: Your question is not about set theory, logic, probability or statistics so if it is not homework it should be posted in the "General Math" section.
Apply AM-GM on ##2abc+a^2b+ac^2+b^2c+b^2a+bc^2+a^2c##.
Thanks both.
Another common tactic is to start by dealing with the case where one or more variables is zero (i.e. lower bound of real non-negative expression is zero). After that you may assume all a,b, c are positive, then divide them out so all variables are on one side.
In this case you'd take advantage of positivity and divide out ##abc## from each side. With a small bit of insight, you'll see that your problem 1 is just an n =3 case of problem 4.
I think ##3(a+b)(b+c)(c+a)=(a+b+c)^3-(a^3+b^3+c^3)## can be of use. At least one doesn't have to deal with so many terms.
Thanks in advance
Induction would work only if a,b,c were restricted to the domain of natural numbers and then again you would have to do triple nested induction. But here a,b,c are any positive real numbers.
Just expand like @Buffu suggests and then use ##(x+y)\geq 2\sqrt{xy}## (already suggested by @QuantumQuest )for proper x and y for example ##x=a^2b,y=bc^2## e.t.c
