What is the proof that the divergence is normal to the surface?
The discussion clarifies the misconception that divergence is normal to a surface defined by the equation f(x, y, z, ...) = C. Instead, the normal direction is determined by the gradient (∇f) of the function. The proof provided demonstrates that the gradient is orthogonal to the displacement vector (Δr) between two points on the surface, confirming that ∇f is indeed normal to the surface. Rigorous proof may involve ε-δ analysis, but the fundamental concept relies on the chain rule and properties of gradients.
  • Understanding of vector calculus concepts, specifically gradients and divergence.
  • Familiarity with the chain rule in multivariable calculus.
  • Basic knowledge of surface equations in three-dimensional space.
  • Experience with ε-δ proofs in calculus for rigorous analysis.
  • Study the properties of gradients in vector calculus.
  • Learn about ε-δ definitions and their applications in proving limits and continuity.
  • Explore the relationship between gradients and level surfaces in multivariable functions.
  • Investigate the implications of the normal vector in physics, particularly in fluid dynamics and surface theory.
Students and professionals in mathematics, physics, and engineering who are interested in vector calculus, particularly those studying surface properties and multivariable functions.
swampwiz
If I am given a function
f( x , y , z , ...) = C
then the normal direction to it is simply the (unit vector of the) divergence of the function. How has this been proven?
It can't be proven because it is not true. Divergence is a number.
Did you mean gradient ?
Here's a handwavy proof that can be made rigorous:
Take two nearby points ##A## and ##B## on the surface ##f(x,y,z,...) = C##, let ##\Delta \vec{r}## be the displacement from ##A## to ##B##. Then the change in ##f## will be approximately given by ##f(B) - f(A) = \nabla f \cdot \Delta \vec{r}##. Since ##f## is constant on the surface, ##f(B) - f(A) = 0##. So we have:
##\nabla f \cdot \Delta \vec{r} = 0##
which implies that ##\nabla f## is orthogonal to ##\Delta \vec{r}##.
Equivalently, if c(t) is a curve on the surface ##f(x,y,z,...)=C## then ##f(c(t) = C## so ##df/dt = 0##. By the Chain rule ##0=df/dt = ∇f⋅dc/dt##. Since ##dc/dt## is tangent to the surface for all such curves ##c(t)##, ##∇f## is normal to the surface.
Yes, I meant gradient.
This works for me. I presume that making this rigorous requires some tedious δ-ε analysis.
Why? All you need is in #4. It is just the chain rule, which I assume you have already done your epsilon delta construction for.
