What is the relation between positive and negative charges?
The discussion clarifies the relationship between positive and negative charges in the context of electric fields. Positive charges act as sources from which electric field lines emerge, while negative charges function as sinks where these lines terminate. In neutral atoms, the charge of electrons and protons is equal, but materials can gain or lose electrons, resulting in a net charge. The fundamental principle governing these charges is that like charges repel and opposite charges attract.
  • Understanding of basic electrical concepts, including electric charge and electric fields.
  • Familiarity with atomic structure, specifically the roles of electrons and protons.
  • Knowledge of fundamental particle properties, such as mass and spin.
  • Basic comprehension of conservation laws in physics.
  • Research the concept of electric fields and their representation in physics.
  • Study the behavior of conductors and insulators in relation to electric charge movement.
  • Explore the principles of electrostatics, including Coulomb's law.
  • Learn about the role of electric charge in atomic interactions and chemical bonding.
Students of physics, educators explaining electric charge concepts, and anyone interested in the fundamental principles of electricity and magnetism.
abi.ayan
Is it the absence and presence of an electrical fluid called as positive and negative charges?
hi abi.ayan! welcome to pf! :smile:
if you want to think in terms of fluid, you can regard the electric field as a fluid which obeys conservation of mass except at the position of electric charges …
then the positive charges are sources, and the negative charges are sinks :wink:
what do mean by sources and sink?I don't have much knowledge in terms related to this field.so could you explain it in simple terms??
A source is a location/object out of which the 'fluid' will appear to come out of. A sink is just the opposite - it is where the 'fluid' appears to go and vanish. So if you were in a bathroom, the tap would be your source, and the drain your sink. Similarly, field lines emerge from positive charges, so they are called sources, and vice versa for negative charges.
Likes 1 person
In a neutral atom the charge of the electron and proton are equal. The atoms of many materials are able to gain and loose electrons giving them a net charge. If the material gains electrons it has a net negative charge. If it looses electrons it has a net positive charge due to excess number of protons.
In a conductor Electrons are free to move from atom to atom. The protons are fixed in place. The protons appear to move but it's really the "absence of electrons" that is moving.
Some fundamental particles have a property that we call electric charge. The rules that this property seems to obey tell us that there are two different "types" of charges, which we have labeled as positive and negative. According to these rules, two similar charges will repel each other while two opposite charges will attract.
The relation between positive and negative charges is simply that both are types of electric charge. Electric charge is only one of many different properties that particles have. For example, mass and spin are also properties of particles.
  • · Replies 58 ·
  • · Replies 24 ·
