What is the Relationship Between Concurrence and Three Tangle in Quantum States?
munirah
Good day,
May anyone help me to confirm the formula use for three tangle using concurrence.
From my reading,
three tangle,
$$\tau=\tau_{A(BC)}-\tau_{AB}-\tau_{AC}$$
and it can be related to concurrence
$$\tau=C^2_{A(BC)}-C^2_{AB}-C^2_{AC}$$
and I used formula for C is
$$C^2=2-(Tr\rho^2_1+Tr\rho^2_2)$$ where $$\rho$$ is partial trace.
[FONT=Georgia, Times New Roman, Times, serif]
When I calculate the GHZ state, I get zero. It suppose $$\tau>0$$ for GHZ state and $$\tau=0$$ for W state
May I know, what it mean by the $$\tau$$ here. Please help me.
And How I can calculated the density matrix of the state using three tangle. May anyone show me an example. I'm really stuck. Please help me.
Thank you.
Thank you Greg Bernhardt. It is ok for this. I will make other question.
munirah said:
Good day,
From my reading,
three tangle,
Thank you.
can you share me how to calculate the tangle. Its very urgent thing for me. And if possible please send me the code for that.
Hello,, even I am also struck in this. It is very needed for me. can you please share me how to calculate tangle manually and if you have code please send me. It will be a great helpfull for me. please send me today. Most wanted problem.
Welcome to PF. :smile:
This thread is over 5 years old, and the Original Poster (OP) has not been here since 2017. If this is a question for your work, start a new thread in the appropriate technical forum, and show what you have found so far. If this is for schoolwork, start a new thread in the Homework Help forums, and show your work on the problem.
BTW, please do not use text speak like "please" at PF. It is not allowed. Thank you.
Sorry for the mistake Sir. It won't repeat again.
Thank you.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
