What is the relationship between critical angle and negative refractive index?
The discussion revolves around the relationship between critical angle and negative refractive index in the context of optics, specifically using Snell's Law. Participants explore how the critical angle is defined and its implications when dealing with materials that have a negative refractive index.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants examine the formula for critical angle and question its applicability when dealing with negative refractive indices. There is a discussion about the conditions under which total internal reflection occurs and the implications of substituting negative values into Snell's Law.
The conversation is ongoing, with participants sharing insights and references to external materials. Some express confusion about the criteria for critical angles, while others suggest that the critical angle could be valid under certain conditions. Multiple interpretations of the problem are being explored.
There is a noted lack of specific information regarding the exact value of the negative refractive index, which contributes to the ambiguity in determining the correct answer. Participants also mention that some of the referenced materials contain advanced concepts that may not be fully accessible to everyone involved in the discussion.
Tanishq Nandan
[/B]
Snell's Law:
n1sin(i)=n2sin(r)
Critical angle=sininverse(n1/n2) [**only works when n2>n1]
If a light beam is incident at an interface of 2 mediums(with r.i n1 and n2) at an angle greater than the critical angle,the interface acts as a mirror,reflecting the entire beam.
I thought of it in terms of critical angle,and saw that according to the formula,critical angle's coming out to be some negative value.Doesn't this mean that any angle of incidence greater than that(which is practically every possible light ray) will have i>critical angle and undergo reflection??
So,I thought option C to be correct.
However,answer's A.
Help appreciated.
I haven't heard of this before, but it would just seem to be a result of substituting -n for n in Snell's Law...
https://skullsinthestars.files.wordpress.com/2008/08/negativerefraction.jpg
I know,I accounted for the given answer in the same way,but only after I had consulted the answer key.Before that,I was thinking about critical angles..and I still can't find the wrong in that.The only criterion for the formula,as I stated earlier,is n1>n2,which is obviously true since n2 is negative
OK, good point! But the condition for the existence of a critical angle would not be n1 > n2. I think it would be n1 > |n2|.
In this question, medium 1 is air. So n1 ≈ 1. Then, in order to have total reflection, you need |n2| < 1.
Some of the articles I found on the net mention materials with n2 = -0.3. So, this does satisfy |n2| < 1.
What would be the value of the critical angle in this case where n1 = 1.0 and n2 = -0.3?
So, you can see that for this case, answer C looks correct.
For n2 < -0.1, |θ2| is always less than θ1, and answer A would be correct.
TSny said:
n1 > |n2|.
Ok...
But the question just says negative..and nothing about the value.I found your link interesting. .but a few(a lot,actually) of things looked kinda out of my league
Ok...
Yes. So, it seems A or C could be correct. The only thing that I see that might dismiss C is that the angle of reflection does not look quite equal to the angle of incidence.
Same here. Some of the slides do use advanced physics concepts. But overall I was able to get a better understanding of the topic.
