ramstin
- 18
- 0
What is the difference between Mathematics and Physics?
simon009988 said:math relies on a set of postulates and logic to prove something, where as physicist use experimental results to "prove" something
Cosmo16 said:That isn't really correct either- a lot of phyics is proved theoreticly without experimental data. Proved using mathmathiimatics.
Pengwuino said:Well something is never really proven in physics until an experiment confirms it and even at that, its never 100% proven.
ramstin said:What is the difference between Mathematics and Physics?
cepheid said:Ummm...no. Physical theories are formulated mathematically to describe the physical world. That doesn't mean that anything has been "proved" about physics though. If they are good theories, then they should be predictive, i.e. one should be able to go out and do an experiment that may or may not bear out the predictions of the theory. If it does, then that lends credence to the theory. On the other hand, if it the experimental results are inconsistent with the theoretical predictions, the theory is scrapped, even though it was mathematically correct and self-consistent. I hope that this illustrates the difference between science and mathematics.
robert Ihnot said:Newton [..snip..] held the chair of mathematics at Cambridge.
D H said:Many physicists are directly involved with making weapons of war. Those who are not making weapons know that their developments may well be used to create new weapons in their lifetime. Physicists in general do not have a problem with this.
Mathematicians, on the other hand, are rarely involved with making weapons. They do know that what they create might well be used to make weaponry. This bothers the heck out of them even though this probably will not happen until long after they die.
marsCubed said:For a mathematican the 4th dimension (for example) is an extension of cartesian space into the complex plane.
I'm glad you recognize that this is nonsense. I was concerned until I read your last line.TheDestroyer said:Very nice question ! I'm answering as a physicist, the answer is that there is no different in fact, because the physics is called the in past the mathematics of the nature, and in this century we see that mathematics has become bigger and bigger and reached a very giant levels, that's why they spreaded them into 2 parts named physics and mathematics,
and if you can observe this, every physics scientist is a mathematics scientist also, like Gauss, Airy, Fresnel, ... and too many others, while you can't see or in little cases that chemistry people aren't friends with maths or physics, and the one who hate mathematics will hate also physics
AND TAKE THIS FOR NOTE, THE PHYSICIST WHO HATE OR DON'T LIKE MATHEMATICS IS A LOOOOOOSER, AND CAN DO NOTHING WITH HIS SCIENCE :P thanks for reading my nonsense :P:P:P:P
marsCubed said:hello all, this is my first post, i hope that the answer below helps someone understand this subject a little more.
Mathematics and Physics are not the same thing, although physics does employ mathematics to make it's models of nature.
For a physicist the 4th dimension is bound up with space time as with Einstein's special and general relativity. The math the physicist employs is actually quite different as it is necessarily constrained by the behaviour of natural phenomena, a limit to the velocity of light, time dilation etc.
Mathematics, on the other hand, has no such constraints, it is limited instead to various infinities and singularities which arise out of the numbers alone.
There are ways to talk about one in terms of the other, but the difference is more than can be accounted for by simply substituting labels.
