What is the solution for e^z = -2?
  • Thread starter Thread starter thomas49th
The problem involves solving the equation e^z = -2, which falls under the subject area of complex analysis. The original poster attempts to manipulate the equation using properties of exponents and logarithms but expresses uncertainty about the validity of their approach.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the manipulation of the equation, including squaring both sides and expressing e^z in terms of its real and imaginary components. Questions arise regarding the handling of logarithms and the implications of multi-valued solutions in complex analysis.
The discussion is active, with participants providing hints and exploring different interpretations of the problem. Some guidance has been offered regarding matching real and imaginary parts, and the need to consider multiple values of the logarithm is highlighted. There is no explicit consensus on the approach yet.
Participants note the importance of distinguishing between the real logarithm and the multi-valued complex logarithm, which is central to the discussion. There is also mention of the potential for spurious solutions when manipulating equations involving complex numbers.
thomas49th
e^z = -2
Let z = a + ib
square it first
e^z = -2
e^2z = 4
2z = ln4
z = ln2
but I cannot go anywhere from there. Is what I've done mathematically sound?
Thanks
Thomas
Hi Thomas! :smile:
(try using the X2 icon just above the Reply box :wink:)
Why are you making it so complicated?
Hint: what's ea? what's eib? :smile:
tiny-tim said:
Hi Thomas! :smile:
heheh
[tex]e^{a}e^{ib} = e^{a+ib}[/tex]
Clever stuff
but while [tex]e^{a}[/tex] is just [tex]e^{a}[/tex]. [tex]e^{ib} = \cos b + i\sin b[/tex]
So where next?
Thanks
Thomas
hi thomas49th! :wink:
(just got up :zzz: …)
Next is eacosb + ieasinb = -2,
so b = … ? :smile:
Hi Tim,
I also, just got up :D
Even after 9 hours sleep I cannot see the easy step that must be around what you're hinting at.
I'm going to write this out
e to the a multiplied by cosine of b plus e to the a multiplied by sine of b i gives -2.
Ahh that didn't help. What the bloody hell is it! Good start to the day :(
Match up the real and imaginary parts
Start with the imaginary part. :wink:
You mean compare coeffs?
sin(b) = 0
cos(b) = -2/(e^a)
but we don't know the quantity a
sin(b)=0
Therefore b=?
[tex]b = 0, \pm \pi[/tex] or [tex]\pm 2 \pi[/tex] :)
[tex]cos(0) = \frac{-2}{e^{a}}[/tex]
[tex]e^{a}=-2[/tex]
[tex]a=ln(-2)[/tex]
Same problem as before:(
Unless
[tex]cos(\pi) = \frac{-2}{e^{2}}[/tex]
[tex]-e^{a} = -2[/tex]
[tex]a = \ln(2)[/tex]
but that seems a bit arbitrary
Thanks
Thomas
It is arbitrary; b can be pi+k*2*pi, where k is an integer.
e^2z = 4
2z = ln4
Is "ln" the ordinary real logarithm? Then this step was not sound, because you forgot all of the other solutions. (much like when you take the square root of both sides, you have to consider two possibilities for sign)
2z = ln4
z = ln2
Is "ln" the multi-valued complex logarithm? The identity you tried to use doesn't apply here.
When I took complex analysis, they taught us what the real and imaginary parts of the complex logarithm were:
[tex]\log z = \ln |z| + i \arg(z)[/tex]​
along with the fact that if [itex]e^w = z[/itex], then w is one of the infinitely many values of [itex]\log z[/itex].
Though, the above facts directly using the ideas mentioned in the thread, if you do things carefully so as not to introduce spurious solutions or eliminate good ones. It's probably a good idea to have the ability to do this.
[tex]\log(z)=\ln|z|+i(\theta+2n\pi),\quad n=0,\pm 1,\pm 2,\cdots[/tex]
The imaginary part is like a spiral-staircase that never ends, no basement, no top floor.
Also, to the thread author:
[tex]e^z=-2[/tex]
That's just:
[tex]z=\log(-2)[/tex]
but look at log(-2) "multiwise" in terms of the infinitely-valued complex logarithm:
[tex]\log(-2)=\ln(2)+i(\pi+2n\pi),\quad n=0,\pm 1, \pm 2, \cdots[/tex]
