What is the solution to this separable differential equation?
13 replies · 4K views · last reply
Dao Tuat
Solve the following differential equation
(x+y-4)dy - (2x-y+1)dy = 0
EDIT: Oops, it should be (x+y-4)dy - (2x-y+1)dx = 0
I integrated both sides and ended up with:
[y(2x +y-8)]/2 = X^2 + x(1-y) + c
Did I solve this right, or am I supposed to do something else?
First of all: Which "dy" should be a "dx" instead??
Secondly, you have probably done this incorrectly by fallaciously regarding "x" and "y" as constants in the integration on both sides. This is wrong.
Did you mean [tex]\left( {x + y - 4} \right)dy - \left( {2x - y + 1} \right)dx = 0[/tex]? If so then you have neglected some products.
On the left, [tex]\int {xdy} \ne xy[/tex] and similarly on the right.
If it is, in fact, (x+y-4)dy - (2x-y+1)dy = 0
which is the same as (x+y-4)dy + (-2x+y-1)dy = 0, then it
is an "exact" equation: (x+y-4)x= 1= (-2x+y-1)y.
There exist a function F(x,y) such that dF= (x+y-4)dy - (2x-y+1)dy = 0 and so F(x,y) is a constant. Do you know how to find that F?
Isn't it? It's off by a constant, but that's it unless I'm crazy.
No, because x is not a constant. Consider d(xy). Because x is not a constant this is not just xdy.
Thanks for everyones help. I'm still a bit confused though. Any tips would be very much appreciated.
You are integrating with respect to y, however, so as it is written above that will be equal to xy+c, since when you integrate with respect to y you would treat x as a constant.
But when you differentiate with respect to y, you get
d/dy (xy) = x + y * dx/dy
and x is not treated as a constant, so why should it be treated as a constant in integration?
If you had differentiated correctly there would be no problem. You differentiated with respect to x even though you wrote it as you were going to differentiate with respect to y. If you differentiate xy with respect to y, you treat x as a constant because you are not differentiating with respect to it, hence the derivative of xy with respect to y is simply x.
You cannot simply treat x as a constant in the term (x+y-4)dy and integrate it wrt y, since it is part of the differential equation. An equation can only be solved like that if it is separable into the form f(x)dx = g(y)dy, in which case both sides can be integrated. However, this equation cannot be separated into that form.
On how to solve this equation... I'm stumped!
This is only true for partial differentiation. However, here we are dealing with normal differentiation and integration.
By your logic, d/dy (x) = 0 because you would treat x like a constant. But this is plain wrong: d/dy (x) = dx/dy.
We have had 4 people pointing out that d_leet was wrong. Dao Tuat, have you looked at my response. Can you answer my question?
This is a "separable" differential equation. There must exist a function F(x,y) such that [itex]\frac{\partial F}{\partial x}= y- 2x- 1[/itex] and [itex]\frac{\partial F}{\partial y}= x+ y- 4[/itex]. Can you find F?
